F7 fault code on Hotpoint WD860
Customer has rang to say F7 fault on Hotpoint washer, I have not got this listing, can you please advise. Model WD860
Fault code F7 is a heater relay fault
Posted on Sep 26, 2008
Hotpoint ultimate wd860
First all all unplug it for 2 mins to clear error code. That error relates to heater or pcb fault. Check the wires on the heater then pcb make sure they are tight. Give the relays a tap on the pcb it could be stuck
Apr 25, 2012 | Hotpoint Washing Machines
Hotpoint wd860 fault code F8 what does this mean
Hello,F8 is simply a component failure and you need to replaced the electronic range control (ERC).
Thanks
May 23, 2010 | Washing Machines
We have F-13 flashing. Can you please advise what
Error code F13 indicaters dryer fan or dryer thermistor faulty.
These are to be be found in the top of the washer on top of the heater manifold.
To access them remove top cover.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Aquarius WD640 Front Load...
I have hotpoint WD860 and fault F - 02 motor jammed tacho detached.What happened?
likely a piece of the rotor itself is locged inside. Disassembly is required to see for sure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Thanks.
Hotpoint Utima WD860
The error code F13 is indicating dryer thermistor open or short circuit.
This is located in the top of m/c, and it looks something like a thermostat wired in series with the element, if there is more than one, then it is advisable to replace both..
Plz rate my solution.
Thanks.
Jan 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Oct 17, 2008 | Kenmore Kitchen Ranges
Washing Machines Logo
456 people viewed this question
Top Washing Machines Experts
