Hi Dale, Several factors can contribute to spark plug fouling:
- The air/fuel
ratio may be too rich as a result of incorrect carburetor adjustment or a poorly
performing fuel injection system.
- Worn piston rings or valve seals may allow too
much oil to leak into the combustion chamber, leading to oil fouling.
- The
ignition system may not be performing properly.
- Prolonged idling or continuous
low-speed driving may keep the spark plug from reaching its optimum operating
temperature. Using too cold a spark plug can lead to the same problem.
- A dirty air cleaner can create a too-rich condition which can lead to
fouling.
Have each of the above checked and corrected.
Fuel, oil and carbon fouling can all be the result of different
causes but, once a spark plug is fouled, it will not provide adequate voltage to
the firing tip and that cylinder will not fire properly.
In many cases, the
spark plug cannot be cleaned sufficiently to restore normal operation.
Hence, I always recommend that a plug be replace, once it becomes fouled.
Cheers,
Scott
"If this has helped you in any way, please be kind enough to rate this solution"
