Cameras Logo
Anonymous Posted on Nov 02, 2011
When looking at pics on my camera cannon power shot s31s it is showing graph and other info want to get back to whole screen pic?
Brian Sullivan
Level 3:
  • Cameras Master 27,725 Answers
  • Posted on Nov 02, 2011
Brian Sullivan
Cameras Master
Level 3:
Answers
27725
Questions
Helped
5669308
Points
79191
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
I have a Sony dsc s600 that works great except all the pics come out totally black. Is this caused by a bad ccd?
not usually, it is caused by under eposure make sure you have the settings of the ISO to a level that is complimetary to daylight
set it to 100 and to say scene and take a few pics. Donload them on to the PC and with the software look at the graph that accompanies each pic to see what is happening with th light factor. You can drag areas of the graph and the pic will alter on screen.
Perhapsa the shutter is not opening.. look in the lens and press the button to see if the shutter actuall opens and shuts
Please rate my help++++Thanks for using FIXYA
I turn on my Canon Power shot A75. to take a
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
My cannon s21s has a blank screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
1helpful
3helpful
2answers
Camra dosent show pic
Please see similar problem titled "black screen". Welsbar posted a possible solution as a clarification request. It involves switching your picture mode to TV and changing the shutter speed to 15 seconds, depressing the shutter button for 7 seconds, then opening battery enclosure. Repeat as necessary - I did this twice before I started to see anything on the screen. Twice more before photos start to look okay. Don't know yet if this is a lasting solution, but at least now I can start using the camera again and find out!
According to Welsbar, the problem is an internal part (iris?) that gets stuck when camera hasn't been used frequently.
12helpful
2answers
"graph" on reviewed pictures
Press up or down on the 4-way command button to toggle between histogram, shooting info, custom settings, highlights, or none.
Cyber-Shot DSC-T1 Pics are very bluzzy
This sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Downloading pictures
you can always use a CF card reader to download the pics to your pc... thats one way out and is much faster..
but try this...
1) uninstall the software...
2) Reboot PC...
3) install the software
4) follow the manual to reconfigure the camera..
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
