Question about Pioneer VSXD814 Receiver
Will not turn on.
The power went out last night. When it came back on my receiver would not turn back on. Is there an internal fuse or am I screwed?
  • mike727 Sep 29, 2008
    Is the receiver blown or is there a way to fix it?
  • Gav-la Feb 13, 2009
    Same happened with me as well. Power outage last night - everthing in the house powers on but not the amp.
    Fuse in the plug is fine and tested on otherappliance - Iwould like to know is there an internal glass fuse.
    Problem Solver:
  • 5 Answers
LLLLLAAAAAAZZZZZZAAAAA
Posted on Dec 21, 2009
All the electricity in my neighborhood went out suddenly last night and then came back on. I went to set the clock on my GE Profile Convection stove, model JB960WY2WW and there are no lights on the...
Hi celecsterrhyme,
Most likely a fuse that blew on the component, I'd suggest removing the compartment on that Control unit, and inspecting it from the back. A fuse will be on the PC Board at the rear. If built-in, just unscrew the screws at the side and pull it out.
This has most likely blown due to a power spike.
Easily replacable, just remove it and take it to your local hardware store for a replacment.
PLEASE NOTE: Before working on the appliance, switch it off at the breaker.
Kind Regards
* Please accept my solution if it helped
Sep 01, 2011 | GE Kitchen Ranges
My 32 spectrronic tv died last night no power and no lights is it worth me getting it fixed with a tv repair man
Upto you
My TV went last week
I repaired it myself at a cost of £2 TV shop wanted £80
If you have soldering iron and equipment and soldering skills its a simple task
remove back of tv
detatch power supply board
locate the capacitors that are domed on top and not flat (this means they have blown)
de solder them and solder new ones in their place
if its not the capacitors its probably the internal fuse
Internal fuse cost about 30 pence
and capacitors cost 30-80pence each
Apr 05, 2011 | Protron PLTV-32 Television
Headlights both went out last night. High beams
There is a relay that controls the headlights, volvo calls it a step relay. You will have to check that power is getting to this relay. If not, check all fuses and wiring. If power supply checks out ok, you may have to replace the relay. Let me know if you need any more info or a wiring diagram.
Apr 06, 2010 | 1991 Volvo 740
Wont turn on
Question: Why won't my unit charge while plugged into my vehicle?
From the Garmin site: --> Answer: If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece. fileservlet?date=1&kb={6b85cfa0-194d-11dc-44cd-000000000000}&id={6e53bea0-6874-11dd-436f-000000000000}&ext=jpg
  2. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  3. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
fileservlet?date=1&kb={6b85cfa0-194d-11dc-44cd-000000000000}&id={6e476290-6874-11dd-436f-000000000000}&ext=jpg //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 08/12/2008
Sep 21, 2008 | Garmin StreetPilot C330 GPS Receiver
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
NAD AV713 receiver won't power up
I had the same problem with mine AV713 it turns out to be the relais of the power unit (left site above the transformer). solution may be to replace it with http://ecb.omron.com.sg/pdf/relay/power/G5PA-1.pdf e.g. good luck TB
Nov 20, 2007 | Sony A/V Receiver
Stopped working
Try getting in your car and turning on all of your accecories like windsheild wipers interior light turn signals ect.if other accesories are not working locate your fuse panel and look for a fuse that corresponds to an accesorie that is not working ,replace it and it should work.If the cd player is an aftermarket cd then they have an inline fuse on the back of the unit either directly plugged into the stereo or it there will be a fuse in one of the power wires.replace if blown and you should be fine,Rate me FIXYA! if this helps.GOOD LUCK.
Nov 18, 2007 | AudioBahn A1000N CD Player - CD Receiver...
Flashing lights
you may have to check the power cord and if that is in place and okay, you will have to check the fuse on the ups. if all that does not work, send it back to the comany for repairs or contact a repair personnel
Sep 01, 2007 | APC Smart-UPS 700INET (SU700INET) UPS...
Pioneer VSXD814 Receiver Logo
105 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
