Question about Samsung PCN5425R 54" Rear Projection Television
Samsung projection tv 54R2HE To resovle the problem
Dear whom may concern
On (date) ,11-01-2006 I purchased a samsung projection TV, Model No; SP54R2HEX/XTL Serial No ADHW31iyb00068A at (Bajaj electronics shop no; 7/8/17/18 M.P.M Dhimal complex (Big bazaar) Ground floor Abids cross road 500001 Hyderabad INDIA 6-01-2006) phone 040-66682297
Unfortunately, picture tube manufacturer fault has not performed well I am disappointed because the product does not work properly, the service was not performed correctly, I was billed the wrong amount, something was not disclosed clearly and was misrepresented, since last six months TV was not working when my mother is calling to Mr Brigmohan(manager of bajaj electronics hyderabad ) ,he is not responding. they took twice tv, for repeairings but tv is same condition, nothing has been change, still is not working properly as before.now they demand to pay more money RS 15.000 which I paid already but still TV is same condition, nothing has been change, still is not working properly, condition is same as before.
To resolve the problem, I would appreciate I that you would exchange my Projection TV to LCD one, or give my money back . I look forward to your reply and a resolution to my problem Please contact me at the address e-mail or phone shown above. bmw424@yahoo.com
SOURCE:
  • 1030 Answers
SOURCE: my samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Posted on Jan 03, 2008
ramon49
  • 111 Answers
SOURCE: Green out of alignment on samsung rear projection tv
LOOK for 3 parts that start with STK (BLACK THINGS THE SIZE OF A MATCHBOOK) then replace all 3 (ebay) also look for some green coils that may be burned. If you SEE THE STK's then your in luck, as 95% of them are bad.. Please rate!
Posted on Mar 30, 2009
jomabug76
  • 1148 Answers
SOURCE: Samsung 47" HD Projection TV with color distortion
COLOR CONVERGENCE IN THE MENU
Posted on May 15, 2009
vortash
  • 431 Answers
Hi luke I am in the uk and not familiar with this set is it a three tubed crt television or an lcd projector type .. either way what you are descibing is convergence ( three primary colour guns all pointing at the same spot in a nutshell ) in the case of a crt projection tv three tubes one red one green one blue .. there should be a convergence pattern in the menu to re set the convergence via the remote check the manual . If it isn't adjustable you may have a scan coil fault or a tube ie : green with low emission check the green colour gun transistor and associated circuit for leaky caps resistors that have changed value or transistor leakage .. and don't forget the ever popular dry joints on the scan coil plugs .. hope this helps Vortash
Posted on May 29, 2009
  • 8457 Answers
SOURCE: I have a samsung projection tv model PCL545r. Turns on then off.
Ur tv leaking coolant,burn parts?Take to shop for clean hazzard materials,change what cause the burn parts by the chemicals.
Posted on Nov 23, 2009
Can't turn on TV
Since when does 2 years equate from purchase date of 2008 and the date at present 2017.
Probably a power supply issue caused by leaky capacitors.
Apr 04, 2017 | Samsung HPT5054 50 in. HD-Ready Plasma...
DLP TV lamp went out, new one doesn't work either,
Well you have a Samsung TV, in this case, it's most probable that you might have an issuw with your ballast. It might not have enough energu to keep up with your new lamp. You might ask yourself, How could this be if it worked with the old lamp? Well the old lamp didn't have all of it's gases, like it used, when you recently purchased the tv or lamp, and as time goes by, those gases tend to go out.
Aug 11, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Color Wheel installation
You can purchase color wheel of Samsung HLT5075SX from Part Store and I would recommend to have qualified TV tech for installation. it is not advised to novice to get involve in such kind of repair that can damage TV.
Still you want to repair it by yourself then download service manual copy of same TV from HERE for small fee that has proper info.
Aug 05, 2009 | Samsung Televison & Video
Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Jul 08, 2009 | Televison & Video
TV on lights keep blinking off and on but tv won't come on
The problem can be caused by either a Bad Main bd or a Bad Power Supply bd. Those two boards are the common failures. Other boards that can cause this are the T-Con bd and the Inverter bds.. To determine if your tv is in or out of warranty you need to look at your tv Purchase Receipt and see what the Purchase date is. Samsung gives you a One Year parts and labor warranty from the date of purchase on your set. You can also call 1-800-Samsung for more assistance.
Jul 05, 2009 | Samsung LN40A550 LCD TV
Samsang Tv turns off and on all will.........do we have ghost?
Symptom shows that Lamp is weak and requires replacement.
How old is this TV and have you replaced its Lamp yet?
Apr 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Cold temps/projection tv
No it won't. The tubes are filled with clear ethylene glycol ( anti-freeze)
Feb 02, 2009 | Samsung HLN617W 61" Rear Projection HDTV
TV won't turn on.
Samsung Projection TV Model # is PCK5315R. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound.
Mar 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Red Curvy Lines across top of screen (Unable to converge)
It sounds like a convergence problem to me also. The average cost to repair this TV is around $450.00-$500.00.
Call another service company that is factory authorized to service your TV. Also, try calling your manufacture and explaining your concerns and ask if will pay for repair or at least for the parts. Have model, serial numbers and purchase date at hand.
Feb 23, 2008 | Samsung HCL4715W 47" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
