Question about Nikon Speedlight SB-800 TTL Flash
LCD Stuck No matter what I press on the flash it won't change modes. The LCD is stuck on some sort of repeat mode.
  • 24 Answers
Did you unlock the control keys? If you see an icon of a padlock on the screen you have locked out the buttons and need to unlock it. Look at the buttons and you will see the buttons have lines drawn from one to another. That means when those two buttons are pressed together, they perform a special function. To unlock the buttons you have to press two of the buttons that have the lock symbol drawn to them.
Posted on Dec 24, 2008
Nikon d3100 stuck on flash mode
What do you mean by flash mode?
Have you read the manual how to use the camera?
If nothing from there helps, try connecting it via USB and check if there is firmware update. If even that doesn't help, try acessing menu and doing hard reset from there.
Mar 03, 2014 | Nikon D3100 Digital Camera
Tv stuck in standby mode
Check and replace its main digital board. It is faulty.
May 22, 2013 | Haier Televison & Video
Hi samsung gio won't start stuck in first samsung screen and can't log to recovery mode it gives ramdump and stuck
ram dump if your press vol up+power+home button, but if you wanna go to download mode you must press vol down+home+power button.
it stuck on first screen called boot loop, solution is reinstall or flash new rom on your phone,
follow this if you wanna back to stock rom
or this if you wanna taste off ICS on your phone
Mar 12, 2013 | Cell Phones
We have samsung corded phones at the office i dont know the model name or anything but it is stuck on night mode even when i press the nightmode button what should i do?
Hi, I hope that you have already sorted your DCS problem out, if not then on the handset with Night mode on, with the handset in its cradle dial Transfer 107 then use your volume keys to find out which button has MODE on it. when you have sorted this press the mode button then dial 0000 then choose 1 for DAY. The video link which I have posted will hopefully help, others like this are on YouTube from abbeytel, or by visiting
Jul 21, 2010 | Samsung Prostar DCS-24B-LCD Corded Phone
Mistakenly change resolution...monitor now stuck
ok just restart your computer and press f8 f8 immedeatly after power on and feep pressing f8 f8 untill safe mode menu will appear. then highlight on enable vga mode and press enter then you can see the picture
Jun 22, 2010 | Samsung Syncmaster 940BW LCD Monitor
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 12, 2010 | Canon PowerShot A530 Digital Camera
My flash isnt working on my A835 camera and i have only had it for 6 months
Check the flash mode that your camera is set to. The flash modes are: Auto, Red-Eye Reduction, Forced Flash, No Flash, Slow Synchro, and Red-Eye plus Slow Synchro. You might have the flash mode set such that your camera detects that the lighting doesn't require the flash mode selected. You can try manually overriding the flash mode by pressing left on the circle function button next to the LCD view screen. If you are still unable to manually turn the flash on, try changing the shooting mode with the mode select dial on top of the camera, then if necessary repeat the flash override step mentioned above. Repeat until successful. There is also the possibility that the flash is malfunctioning, but that is less likely than a setting issue. Let me know how you make out.
Jan 02, 2010 | General Electric A835 Digital Camera
Ccdtrv608 sony handycam stuck in nightshot mode
Below image of CCD-TRV608 shows NightShot Button location, turn it Off for normal mode recording.
Mar 24, 2009 | Sony Handycam CCD-TRV68 Camcorder
How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
Nov 12, 2008 | Watches
Dewalt dc011
try removing AA battery may help to reset unit
Jan 11, 2008 | Dewalt DC011 AM/FM Radio
Nikon Speedlight SB-800 TTL Flash Logo
518 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
