How do I remove the drum to change the bearings ?
How can I fix my LG Intellwasher?
I think I need to change the bearing on the drum as they sound very dry and loud, I think the water seal in the drum must have worn. My LG WF-T1330TP 13 kg top loader washing machine is about 5 years old.
This weekend I washed a comforter and somehow the bottom section of the drum came loose.
It appears that it must just clip in -but somehow it is not.
I dont know if we are missing a screw or bolt or something.
Nothing was laying loose in the machine
The machine is still working but I am afraid to operate it like this.
Please te
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: How can I fix my
What is your model number
Posted on Aug 02, 2008
Master_Tech
  • 770 Answers
SOURCE: How do I remove the drum to change the bearings ?
What is your model number ??
Posted on Aug 05, 2008
  • 500 Answers
SOURCE: What is the problem if
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
Posted on Apr 08, 2011
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
My partner's Hotpoint WT960 makes very loud grinding sound when spinning. I suspect the drum bearings are gazacked. Do I need to change the drum support and bearings & seal or just the bearings? Is it...
Hi Joe.
A lot depends on construction of drum.
Remove the top cover and look at the plastic outer container, if it is a one piece consonstruction, then unfortunately you cannot fit new bearings, as it it comes supplied as a complete unit.
However, if you can see the 2 drum halves held together with screws, then you can fit new bearings.
You will not know if the spider or drum shaft needs to be replaced until the it is stipped down, a fifty- fifty chance
It is an involved repair as it entails removing the whole container from the cabinet, and do not fit any other bearings than the genuine ones.
It comes as a bearing and seal kit from Hotpoint.
WWW.HOTPOINTSERVICE.CO.UK
Good luck
Dec 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
How do you change drum bearing on lg wm-1290fhb washing machine
It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
Apr 05, 2010 | LG WM-1290FHB Front Load Washer
Hi, there i a knocking noise during the spin cycle on my hotpoint aquarius 6kg wma56 washing machine?? How do i fix it?
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it
Check for bearing failure by seeing if there is any vertical movement between the moving stainless drum and the fixed outer drum. There should be no vertical movement between them - if there is the bearings have failed and will soon collapse. Check for rusty spray around where the pulley shaft enters the outer drum - early indication of seal and bearing failure. Another method of checking is to remove the drive belt and rotate the drum by hand - there should be no noise, roughness or resistance to rotation. Changing bearings is an involved job, only attempt if you are mechanically competent.
As for changing the bearings.
Power off, remove covers. Disconnect drive belt, remove drive pulley. Remove heater, thermostat and pressure switch. Check if drum splits at front, rear or the middle. If the drum is a plastic welded one- ie one which doesn't split, then its game over. If it splits at front or middle, drum will prob. need removal from machine. This involves dismantling the suspension and damping system and removal of door seal and concrete weights. Undo the drum fixing system - either a clamping ring or a series of peripheral bolts and split the drum. If the drum splits at the rear, removal from machine probably not required. Remove the clamping system and pull off the rear plate. Seal and bearings will come away with the plate. Seal needs to be dug out with a suitable lever and the old bearings hammered out with a punch from opposing sides of the backplate. Refitting is, as they say, a reversal of the above process.
However Unplug the appliance and take the top off.
Check the weight on the top to see if it's slack.
Open the door and with your palm upward put it on the edge of the drum.
Lift it until the weight comes on. Is there a lot of movement?
Press down on the inner drum and swing it side to side, does it sound/feel rough?
Finally, tip the machine rearward a little and from underneath check to see if the front weight is loose.
If all of the above are ok then it's likely the drum support spider has broken one of it's legs and the inner drum is knocking as it spins.
To sort this out you would need to strip the appliance down and remove the inner drum to try and change the bearings and the inner drum support.
This is a major strip down of the appliance.
Hope this helps
Thanks for contacting fixya.com
Nov 12, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
NEED TO REPLACE REAR BEARING.GOT A NEW BEARING.NEED A DIAGRAM ON DISSASSEBLE,REPLACEMENT AND REASSEMBLE. OR SOME HANDS ON ADVICE....THANKS ..TY
really tedious job. if you are really keen, pl. follow.
remove motor, remove shoker top pins, remove top stone, remove all hose connecting drum, remove heater/other connections, remove door gasket from front, support drum from top, remove springs, lower drum, dismantle drum in two pieces, remove inner steel drum.
well rest i think you can think yourself.
Oct 30, 2009 | LG WM-0532HW Front Load Washer
LG/ westinghouse lifestyle font loader
what you will need to do is wright down the model number and go to ebay and put in bearings for a lg then put your model number in and it will come up with very cheap bearings thats where i get all my stock from. good luck £4.50p very cheap
Jan 06, 2008 | LG WM2077CW Laundry XL Front Load...
How to replace the bearings ?
changing the bearing is a huge job. it requires taking the whole washer completly apart
Oct 22, 2007 | LG WM-2277HW Front Load Washer
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
