Question about HP LaserJet 1300 Printer
HP Printer 1320
Paper is going in crooked. As you suggested the left roller is pulling more than the right, how do I adjust that?
  • Anonymous Nov 05, 2008
    setup1320
    Genius:
  • 1,142 Answers
When printing on HP Laserjet 1320 it brings the red light and it does not shows any error. no printout.
there is a paper in it's roller to remove it pull out the tonner and check the roller ther will be a paper stuck in it remove that papre printing will be contnue
Jan 19, 2011 | HP LaserJet 1320 Printer
Paper jam in hp laser 1320
Unplug the power cord and open the cover and remove toner and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 10, 2010 | HP LaserJet 1320 Printer
1320 HP Laserjet Still Won't Pick Up Paper
Please check limiters paper in tray 2 to be on A4, letter, depending on paper format. Otherwise you have problems with taking the sheet from tray 2.
Oct 09, 2009 | HP LaserJet 1320 Printer
HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
HP LaserJet 1320 folds over top left corner of every page printed
I see this problem alot after a paper jam occurs and someone has pulled the stuck paper out. There is probably a piece of paper stuck in the printer somwhere. If you open the front toner door and take the cartridge out, you will see a roller at the bottom front. DON"T touch the roller but take it out. You may find the paper there!
May 24, 2009 | HP LaserJet 1320 Printer
Paper ALWAYS feed crooked.
Defective rollers or you have something stuck in a corner...look carefully or try cleaning the rollers with robbing alchool (remouves grease)
Feb 27, 2009 | Dell 924 All-in-One InkJet Printer
Hp laserjet 1320
You might try this before turning it over to the tender mercies of a tech:
Use a high-quality bond paper and remove any other sheets from the feed slot or tray; 'paint' a stripe of alcohol across the page; preferably pure, rubbing alcohol if you can't get other. Let the machine start to pull the sheet through but hold it so it can only take an inch or so before stopping; hold and release several times and hope that one of the stops is between pinch rollers that will yield up its load of paper fibers.
This is NOT a 'sure-fire' method but can often cure the problem for a while before the rollers load up with paper fiber again. BTW, 'bargain' paper can cause this to happen earlier than quality bond since it has more loose wood fiber that can depart from the sheet and build up on rollers.
Sep 23, 2008 | HP LaserJet 1320 Printer
Paper Jam & Flashing Light
take everything out and look at all the rollers and printer path and look in the back of the printer
Jan 15, 2008 | HP LaserJet 1320 Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Dec 05, 2007 | HP LaserJet 1320 Printer
Print is not straight
It sounds like the paper is being pulled into the printer at a crooked angle. Check that the guides in the paper supply tray are adjusted correctly to the paper width and are tight against the stack of paper. Alternatively one of the rubber pinch rollers that pull the paper though is slipping or worn smooth. Regards
Sep 24, 2007 | HP DeskJet 930c InkJet Printer
HP LaserJet 1300 Printer Logo
62 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
