Question about Rimage Office Equipment & Supplies
The Rimage DL5200, getting error mgs saying the the printer is busy, yet there is nothin in the Q is empty and have tried a reboot. reset cables ect !
pineworks
  • 4041 Answers
SOURCE: Well I'm getting a 502 error, tried to change
Hi there
The best thing I can do is gave you a link to this error 502 because it going to be a big job. so click on this link it tells you what you can do.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 12, 2010
  • 100 Answers
SOURCE: Printer wont boot up.
Follow the steps below to power cycle your all-in-one:
1. Verify that the unit is switched on. Disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
4. Check for the functionality
Posted on Mar 13, 2010
  • 1739 Answers
SOURCE: I have a Canon MX310
Error: Printer is offline
Solution: Set printer from Offline to online
For Windows 7, open Devices and Printers
Right click on the Printer icon and click on See what's printing
Click on Printer to open the drop-down menu.
Click on Use Printer Offline to remove the check mark and allow use online.
For other Windows operating systems, see here.
Posted on Jan 25, 2011
  • 135 Answers
SOURCE: My printer shows "Hardware Error
  1. Remove the power cord from the unit.
  2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
Figure 1: Out-of-position encoder strip
  1. Gently move the top part of the printer belt to the right.
  2. Using your index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
new_note.jpg Note: There is a small slot that the encoder strip fits into, which is located on the back of the ink cartridge carrier.
While working with the encoder strip, check it for dust or any unclean spots. If any detected, try to clean the strip by wiping it gently with clean cloth.
  1. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
  2. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
Figure 2: Correctly seated encoder strip
new_note.jpg Note: If the encoder strip moves at all, it has NOT been repositioned correctly.
  1. Once the encoder strip has been re-seated, close the lid to the unit.
  2. Re-connect the power supply to the All-In-One.
  3. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
Posted on Feb 18, 2011
  • 35 Answers
SOURCE: lexmark 1200 will not scan.
Lexmark is good about providing free assistance, try them for solution.
Posted on Feb 22, 2011
WHAT DO IF I HAVE AN ERROR CODE E7-03 ON MY SHARP PRINTER MODEL NO ARM620N
The code refers to a hard drive issue. This could be caused by a corrupted file or there is an issue with drive itself. First thing to try is to reset the error code. This sometimes works & the machine runs fine after. If the code returns then you could be looking at a new hard drive.
To reset the machine, make sure the copier is in COPY mode, then press the following 4 keys in sequence #*C*
The machine should now be in simulation mode. Enter 14 then press the copy start key. Press the copy start again then press the CA key. The machine should reboot & if the drive is ok the machine should be ready to copy. If the code reappears the its most likely the hard drive is faulty.
Dec 27, 2014 | Sharp Office Equipment & Supplies
Unable to get system manager-Autoloader to ID the media discs. Doesn't show any option for media type. Only sees 120mm standard.
If the autoloader is in ready state, reboot the PC. Check if system manager displays the autoloader drives and printer. Check the firewire cable. It's easy to plug it in backwards. The firewire card can get damaged if it was plugged in backwards.
Aug 18, 2014 | Rimage 2000I Computers & Internet
Rimage 3400 auto loader
R U sure the firmware update was the correct update and that it installed successfully? Check in the firmware part of the burning program to obtain a list of the currently installed firmware.
Apr 07, 2014 | Rimage Professional 3400 NSS CD/DVD...
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
Computer says printer is busy - try later I can't see why it's busy.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 21, 2011 | Lexmark X1270 All-In-One InkJet Printer
Executing OTP version 3.04
Hook a VGA monitor, keyboard and mouse up to it. Then turn it on to see if it's booting into Windows or even into the BIOS. If it's booting into Windows, then download your autoloader firmware from Rimage.com (click the support link, then your model, download the autoloader firmware) -- then unzip it somewhere on your Rimage and use Gemini Utilities to update the firmware in the autoloader. Then restart the computer and see if you still see the same message.
The printer being recognized is tied very closely to the autoloader firmware working. Also, it helps to make sure the printer's switch is set to the position marked for Transport.
Apr 15, 2010 | Rimage DiscLab DL5200 (555101120) Burner
2. Wait 30 seconds.
Mar 13, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hi ,our rimage perfect image sometimes
Most likely the sensor cable is bad. I have them is stock for this printer.
John Norman Max Optical LLC. john@maxoptical.com 610-269-7033
Feb 10, 2010 | Rimage Perfect Image Prism Thermal Printer
Top Rimage Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Rimage Office Equipment and Supply Expert? Answer questions, earn points and help others
