Question about Whirlpool Dryers
Whirlpool Electric Dyer Problem
I am having trouble with a Whirlpoo Electrci dyer. Evrything works, just will not dry cloths. Can you offer a few ideas of what to check.
Model LER7648PTD
    Genius:
  • 1,122 Answers
Most of the time the dryer vent hose,wall vent and dryer vent hole must be clear to allow the dryer to vent,also you can pull dryer hot put you hand on the dryer vent hole turn on and see if it is venting this will let you know if the blower wheel is turning, let me know what you find-mike
Posted on Sep 25, 2008
Whirlpool duet electric dryer leaking water
Check and clean your venting from the dryer to the outside. If it is plugged it will trap the moisture in the machine. Remember heat doesn't dry the clothes without air flow to push the moisture out.
Mar 04, 2013 | Whirlpool Dryers
Dyer will not start, timer is working but dyer does not start cycle
You either have a bad motor or start switch. You might also have a wiring problem.
May 05, 2012 | Dryers
Dryer is about 5 years old. Has begun to squeak loudly when clothes begin to spin
Are you comfortable taking the dyer apart? There are just a few simple screws to remove. It sounds like a bad blower wheel. If you follow the link you should be able to trouble shoot the issue.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info
Mar 01, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
Clothes dyer takes to long to dry, already clean all exhaust vents.
is it gas or electric?if it's gas you could have bad gas coils,they work for a while then cut out leaving clothes damp.if it's electric and heater is working check outside to see if flapper is opening,you might have a blcked vent line.you can remove vent line from back of dryer and run it and if clothes dry you know your vent line is blocked,if it is blow out vent line with leaf blower,short blasts at first so you don't damage vent line
Nov 02, 2009 | Kenmore Dryers
Dryer takes hours to dry clothes.
Sounds like a heating element has gone bad. You have to tear apart more of the dryer to get to it.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
Washing machine low spin rpm's
If the electric motor has carbon brushes, check they are not worn out.
Jul 02, 2017 | Whirlpool Washing Machines
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Kenmore dyer
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
Jun 09, 2008 | Kenmore 62802 Electric Dryer
Dyer
signal level for 10 seconds
Jun 06, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
103 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
