NAD 304 AMP...No Sound at all on both channels, Black marks on inner case.
Hi Guys,
I have no sound on both cahnnels, Ive opened up the case and there are black marks on the top of the inner caseing. That doesnt look good at all, but there appears to be know burn damage to the board on the area this occured. Right below these marks on the inner caseing on the board are two glass fuses, they seem to be intacted as well. The amp powers up fine and shows the green indicator light. Simply no sound out the badger!
Thanks alot folks!!!
  • 1 more comment
  • sircuit84 Sep 27, 2008
    Hi
    Thanks for the swift reply. I think you may have hit the nail on the head. I read on a forum about
    the, pre out and main in section, has to be connected or no sound. Can you please tell me how to connect them and what is the purpose of them, as I dont have them on my other amp.
    I think you may have found the solution:)
    thanks alot dtaylor91
    Hi
    I now have sound out of the amp but it is silly quiet when turned up. Turned up half way I can just about hear it. Maybe I have a blown amp? It was picked up cheap second hand with a marantz cd player that works perfectly fine. I used a standard phono connection not very long as you said. But yeah just really low volume levels.
    Thanks for your last post seems like we are making progress:)
    all the best
  • sircuit84 Oct 23, 2008
    Hi
    Sorry for the slow reply internet has been down. On closer listening it does indeed disort at higher volume levels. But I thought I would give your fuse idea a go anyway. It can now at least be elimnated as it didnt change anything. So what do you think we might looking at here?
    Thanks so much for your last detailed easy to follow post!
I need a power amp. brand that has a 4ohms impedance that who will match my 307d2 4 ohms (pioneer) sub woofer that can use inside my house
Posted on Jan 13, 2010
  • 31 Answers
This may be a silly question, but the pre-out/main-in jumpers are installed, yes?
Posted on Sep 26, 2008
  • dtaylor91 Sep 27, 2008
    Just take a standard, but short, interconnect and plug the left pre-out into the left main-in, and the same with the right. That should take care of it.
    The purpose of them is to allow for future upgrades. In other words, if you find a better preamp that you want to use, you can still use the 304 as a power amp only, by plugging the new preamp into the main in connectors on the 304. Or, you can use the 304 as a preamp for a different power amp.
    OK, From that description the next thing to do, assuming the sound you are getting is undistorted, is to check the main power supply fuses. The other two fuses you described near the "toasty" area feed the preamp section only. If the preamp is fine, which from what you've said so far it is, it will drive the main amp enough to produce some sound even if the main amp is receiving no power at all. The key thing here is, is the sound you are getting out so far undistorted? If so, you may be ok after installing new main amp fuses. They are in dead center of the circuit board, two of them are 3.15A, and the other two are 5A. Use "fast-blo" fuses only.
    With new fuses installed, leave the cover off the amp, DISCONNECT the speakers and the CD player, keep your hands well away from the amp, with the exception of using one to press the power switch while you are watching those new fuses. If they immediately blow on power-up, there will be a bright flash, and then we'll have to discuss replacement of quite a few large power transistors.
    If they don't blow on power-up, it will appear nothing happened. Turn the amp off, connect the speakers only, leave the volume knob all the way down, and turn the amp on again while you watch the main fuses. If they blow THIS time, there are issues with the main amp that will take more to address than I can do without sticking my head into it myself (will a boatload of test equipment). However, if the fuses don't blow on this second try, start slowly turning the volume knob up while you keep an eye on the main fuses. If they blow at a certain point on the volume knob, there are issues in the preamp that will need to be dealt with, but this is very rare with the more vintage NAD preamps. You are more likely to be hit by lightning sitting in your living room than the preamp having blown!
    IF the fuses have survived so far, you SHOULD (fingers crossed) be home free. Connect everything up and give it a listen.
Hi ihave nad 304 it keeps blowing 5 amp fuses
Most likely caused by a shorted output transistors on at least one channel + possibly some other components they took with them... but maybe you are lucky and you have a shorted power capacitor or something.
Mar 14, 2015 | NAD Audio Players & Recorders
My NAD C320 outputs a very low sound volume
Hi there I have a C340 that has similar problem, you must have bought this from ebay, lol.
Nad made a mistake on the C range, the pre - power link can be shorted out. if the pre is shorted out it takes out the pre amplifier stage, I have managed to get the right channel working, I will keep you informed what is the cause of the left channel. I have replaced the pre-amp IC and a couple of Jfets and transistors. Once I have repaired the Amp I could repaire yours if you like???
Apr 14, 2012 | NAD C320 2-Channel Amplifier
No sound from left channel.
hi
first of all you can check either amp or pre is defect. for this change wiring left to right and right to left (pre to amp wiring). if still left channel has no sound the problemmaker is the amp. would be helpfull for further assistance if i know the model number.
regards
Feb 09, 2011 | NAD Audio Players & Recorders
Where do I connect the speaker wires?
Because your amp has 4 channels on it on side A you can connect 2 speakers for left and right and the B you can do the same. your red is positive and black is negative. so in total you can have 4 speakers connected to your amp
Jul 26, 2009 | Audio Players & Recorders
AUX problem between my laptop and NAD C 320BEE
HI...
I would check on the Soundmax software set-up on the PC and make sure that the AUX is set for a line-out connect.
Also,make sure the tape monitor isnt on ..On the amp
Mar 01, 2009 | NAD C320 2-Channel Amplifier
Sound through one channel only.....NAD 310 Amplifier
If swapping of left and right input sources and left and right speakers does not help...you might have a bad channel in your amp.
Sep 24, 2008 | NAD Audio Players & Recorders
No sound output, regardless of channel selected, for 30-60 seconds
Hi Dan
The first click is the power relay connecting up the main transformer, the second click you normally hear is the speaker protection relay. When a fault condition is present in the amp, the protection circuit prevents the speakers connecting to the amp by NOT operating the relay. As the unit "settles" and works after the delay you noticed, what ever issue the amp is balancing itself it. It sounds like a leaky capacitor in transistor in the output stages. This can often be located with quick bursts of freeze coolant spray. It may also be a dry joint in the soldering about the driver and output transistors, always pays to have a visual look at it whilst you are in there. I also check power regulator stages for dry joints. The fault will be on one channel if it is signal path related, and both channels if power supply related. If you are familiar with electronic repairs, get in and have a look yourself. If not, get a NAD service guy to take a look at it for you. Good luck. Feel free to ask me any questions you may have about it.
regards
robotek
Aug 14, 2008 | NAD C370 2-Channel Amplifier
Only the right channel had a sound,the left channel is mute, whatever adjustment you did and whatever balancing you done nothigs happen,even you interchange the speakers. The problem is in the power amp. The STK IC there is busted already, it's better to change it with a new one so the performance become normal again.
Jun 14, 2008 | NAD C372 Amplifier
Pop in left channel
Hi i don´t speak a good Englis but i think what you have a problem whit a filter in the preamplifier, just in the final amplification block, open it end check for any spill o exploded filter
Dec 03, 2006 | NAD T163 Amplifier
951 people viewed this question
 Grubhead
Grubhead
