Related Tags:
This problem should be removed because:
Problem with Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
solution is not dispensing but machine sucks up water plus the spinner on side of machine does not spin
Suggested Solution (2)
I also found that the Heater wqas the problem. It is the outlet port on the heater that gets clogged.
Source: cleaner suddenly stopped working
You need to replace the pump belt. Here is the belt you need and the manual:
Bissell 8910 ProHeat Belt and Manual
Hoover Steam Vac Spin Scrub Carpet Cleaner...
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I...
No dispensing of water from container.
The water in canister is not dispensing. Cleaning fluid releases but no water dispenses when lever on handle is held down to do so.
Hoover steam carpet cleaner brushes dont spin
The brushes on the machine dont spin when it is on, it sucks the water up though....
I have a new Hoover
I have a new Hoover Dual V steam vac that I bought from a neighbor who only used it once. I have only used it once since then and it worked...
Will not put water on
Will not put water on carpet. Red spinner not moving. Does move briefly some times. Removed Belt cover, spinning. Removed red spinner and...
Tips for Helping caroline major With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
need manual and scamatics for oreck carpet...
need manual and scamatics for oreck carpet shampooerWhat's your problem?
hand attachment does not spray
The water does not seem to spray.
Bissel proheat 7901 rear wheel broke off. How do...
The rear wheel cracked and eventually broke off after a recent move. Axle is still in place.
Manual, anyone?
Does anyone have a manual for a Bissell SC Carpet Extractor 1632?
See all Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Problems
Fix-O-Meter
78
78 people viewed this problem
- 0 people are following this problem. Be the first!
Top Bissell Vacuum Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
