User manual for phillips professional pocket memo 198
I want to download a free user manual for a Mini tape recording machine
  • 61 Answers
Go to www.dictation.philips.com and find the support section for manuals.
Posted on May 18, 2010
Phillips Pocket Memo 381 The button you press in when recording will not press in! Any ideas tThe machine plays back tapes OK
You cannot push it in without a recordable tape in the unit. The mini cassette tapes have a removable erase prevention tab on each side in the front. If removed, you cannot push record. Try another tape. Otherwise the recorder needs repair.
Aug 16, 2011 | Philips Pocket Memo 381 Handheld Cassette...
Our 9500 series Philips digital pocket memo will not clear the old files when complete. As a result, we are unable to download new files. Any help would be appreciated. Thanks! Jill
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
Apr 05, 2011 | Philips Pocket Memo 9500 (256 MB 1 Hours)...
I have a Philips pocket memo 381 that lets out a loud bleep when trying to record on it. Batteries have been changed twice this makes no difference.
This is the end-of-tape signal. Try turning the cassette over. If this does'nt work then there is no tape drive due to the belt coming loose or breaking.
May 05, 2010 | Philips Pocket Memo 381 Handheld Cassette...
I have an old Philips Professional Pocket Memo 398 but have lost the manual. How do I wipe the cassette?
At the end of the recorded part of the tape, hold in the RECORD button and pull the 4-way slider down into
REWIND position. Hold both until tape is fully re-wound.
Jan 25, 2010 | Philips Audio Players & Recorders
LFH 720 - Does it record?
This machine is a playback-only model. You will need a hand-held recorder using Philips mini-cassettes.
Oct 13, 2009 | Philips LFH-720
Philips Pocket Memo 398 dictation machine - spindles not turning
Most likely cause here is a broken drive belt. This machine is at least ten years old. The belts for the latest model (381) will fit, but it's a tricky job to fit.
Mar 25, 2009 | Philips Audio Players & Recorders
Phillips 281 pocket memo
Go to www.dicatation.philips.com and download manual for model 381. It works exactly the same.
Mar 02, 2009 | Philips Pocket Memo 281 Handheld Cassette...
123 people viewed this question
 Grubhead
Grubhead
