SOURCE: firing order
Hello bailsdenied: THe fireing order for a Acura NSX 3.2L DOHC (vtec) engine is 1-4-2-5-3-6. If this is the correct model of car then it is right. If this is not the right car then ask and I will send the correct one. Please rate the answer you recieve as this lets us nkow you were provided the correct answer to your question. Thank you for using FixYa. Roger
SOURCE: trying to replace a front headlight bulb on 2001 acura 3.2 TL
Look for the end of the wire retainer clip. Unhook it and lift it up. Remember not to touch the bulb. But if you do, just clean it with a bit of alcohol.
btw - Here's a bit of info from a previous post of mine...
The low beams consist of three parts. The bulb, inverter/ballast and
the ignitor. The bulbs usually start to loose their color long before they burn out.
The inverters/ballasts either go out after a while or take a while to
start up.
Before you spend money on a new bulb, try swapping it with the one on
the other side. You'll need a security torx screwdriver to get the
covers off of the back of the lights. Don't touch the glass bulbs. If you do, just clean them with a bit of alcohol.
If the problem stays on that
side, try swapping the ignitors. They're mounted inside the black
covers.
If the problem is still on that side you've got a bad inverter. They're
mounted on the bottom of the headlight assembly. You'll need to remove
the front bumper and remove the headlight assembly to get to it. (I
recommend you take pictures as you remove things so can put them back
together correctly.)
SOURCE: starter replacement on acura 2000 TL 3.2
This starter can be changed without disassembling the top of the engine on the 2.5 with automatic transmission. You will need a 10mm, 14 mm, 17mm, and a 9mm wrench. First with any electrical repair disconnect the battery at the negative terminal. The starter is on the driver's side close to the firewall below the intake manifold. Remove the transmission dip stick so you don't ruin it, then look and study the starter itself. You will notice the starter drive housing with a top and bottom bolt. The top bolt is a 14mm and the bottom a 17mm, loosen both a half turn. Remove the top 14mm bolt first, then the bottom 17mm, this will allow you to pull the starter out of the bell housing. With some angling and no brackets holding the back of the starter you should be able to pull it out enough to disconnect the positive wire and 9mm nut from the soleniod. Disconnect the starter ignition small wire by pulling it off it's connector. Now just pull it out of the engine and fender void and you've got it, saving about a hundred and fifty dollars of labor. Take it to the parts house and match it up with a well made remanufactured or new starter. Reverse the proceedure, hook up the battery.
SOURCE: P0505 idle control system malfunction
Take the Idle Air Control valve off the bottom of the Throttle Body and clean it. If that doesn't work you may need a new one. Please rate me if you find this helpful, thanks.
SOURCE: 2000 acura TL horn blows when replacing the battery
dont you have the alarm key fob? if so that will reset it. just press unlock. If you dont an dits not a OEM Acura alarm you will need to find who makes it and get a new key fob, or have a shop that does alarms to disconnect it.
Testimonial: "thank you so much. Like most solutions, it was simple and obvious once you pointed it out. I really do appreciate the help!"
