Question about HP Pavilion dv6000z Notebook
Display when i was updating some window softwares asked by laptop updations.3 of 6 got updated but 3 were having some eror.than restart now option comes.i pressed it ok.after restarting nothing comes on display.it is totally off now.but working is going on in it.
  • 186 Answers
First of all, we need to check whether it is the LCD Display of the Notebook which is faulty or any other thing....
Turn on the Notebook and check if you are able to see the HP Logo or the POST instructions during startup or not. If yes, the issue cannot be with the Display since if it is faulty, you should not see anything on it.
If there is no HP Logo or POST sequence displayed during startup, we need to suspect that the issue is with the LCD and go ahead with checking it by following the steps listed below for which we need a Desktop Monitor to do so :
Turn on the Notebook and once you are sure that the Operating System is completely loaded, connect a Desktop Monitor to the Notebook once it is turned on and press FN + F4 so that the Display of the notebook will be toggled on to the Desktop Monitor connected and check.
If you are able to see the display on the Desktop Monitor and not on the LCD, we can come to a conclusion that the issue is with the LCD of the Notebook. However, if there is no display either on the LCD or on the Desktop Monitor connected, the issue should be with any of the hardware components of the Notebook and it should be repaired. You need to contact HP Support if the Notebook is under warranty and get it repaired for free.
However, if the notebook is out of warranty and is installed with AMD Processor, you can get it repaired for free.
HP had iedntified a issue with few Notebooks which are installed with Amd Processors for which it is arranging free repairs in US and Canada.
You need to get the Product Number of the Notebook which can be found printed on a white sticker at the bottom of the notebook and is indicated with P/N  and find if it is listed among the list provided in the link below or not :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01300427
Better way is to copy and paste the entire link in the address bar of a new web browser and press enter.
Press Ctrl + F key and type in the Product Number of the Notebook without #ABA  and if your Notebook product Number is listed, then you need to contact HP via Chat Support if your Notebook is out of warranty and let the support technicians know the steps you have done to confirm the issue where they will be able to arrange free mail in repair for your Notebook.
You can find more information about this free repair program offered by HP from the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Hope this helps....
Posted on Sep 25, 2008
How do I fix Windows 10 update 0x800705b4 error code?
This error commonly occurs within the operating system at the time of windows updates. If this error is not fixed, it will lead your system slow or even corrupt it.
This error may arise for the following reasons,
1. windows defender update
2.
Damaged system files.
3.
Third-party anti-virus and malware.
Solution for the windows 10 updates 0x800705b4 error code:
Right here are a few solutions for troubleshooting 0x800705b4 error code,
Method 1: Uncheck the "get updates for other Microsoft products when you updates windows" option:
• Open the "Windows Update" and click "Advance Options".
• Uncheck the "get updates for other Microsoft products when you updates Windows" Option if it's marked.
• Now the update process should complete successfully.
• You may run this process continuously until you get the "your device up to date" message.
• Once this message appears, again check/select "get updates for other Microsoft products when you updates Windows" Option.
Method 2: Temporarily disable the "Windows Defender"
• In case, the above solution doesn't work, you can disable the" Windows Defender" for temporarily.
• Type Defender in the search box and open the Windows Defender Desktop app.
• Click "Settings" and turn off the Real-Time Protection and Cloud-Based Protection options.
• Close the setting window and now the windows defender appears in red.
Note: After that do all the steps in solution 1 again, hope the update process will be successful this time. Once this issue is fixed, you can turn on both Real-Time Protection and Cloud-Based Protection.
Method 3: Run the Windows Update in "Clean Boot"
You should login computer as an administrator for performing "Clean Boot".
Method 4: Run the "Microsoft Update Troubleshooter" and Restart the Windows Update:
Still, if you having update issue, download the "Windows Update Troubleshooter" and Run.
After this, restart the "Windows Update Service".
Follow these steps for Windows Update Service restart,
• Open the Command Prompt(CMD)
• Type "net stop wuauserv" then press "enter"
• Wait for the confirmation message.
• Then type "net start wuauserv" then press "enter"
Hope the above solution will fix the update issue.
Jun 12, 2017 | Computers & Internet
I want to update nokia e5
You need active internet connection for this:
1. press #0000#, then it will display you the current software version that your phone is using.2. press option, then select check for updates.3. it will then go to connecting to internet, select yes.4. if there is available update, you will be provided instructions that the phone is updating software.5. you will be ask to replace the old version with the new version, just select YES.6. your phone will restart, that's part of the software update.7. after restarting, your phone will now be using the latest version available for your phone.8. you can again check the current version of the phone's software by entering *#0000#, then you are good to go.
You can also try to this:go to settings --> software update --> download available updates --> phone will restart --> you will be using the new version of the phone's software after this.
Thank you for choosing www.fixya.com
Dec 08, 2011 | Nokia E5 Cell Phone
Hi i have installed windows 7 pro on my e system laptop when windows updates found and updated all the drivers and needs to restart laptop then after coming the welcome screen the screen is totally...
there might have been an issue with the windows update , from what i see it seems to be a display driver issue that occurred from the update, try pressing the F8 key at the screen before the welcome screen to go into advanced boot options, then select boot in safe mode,then you should be able to access your account ,then run system restore,by going to the following location : C:\Windows\System32\rstrui.exe and hitting enter or searching for rstrui.exe in your start menu search bar then run it, then when the restore window opens up, select a restore point before you installed the updates, then after going threw the easy steps let the process begin by hitting the finish button ,and wait until it finishes then you should be able to use your computer again, i suggest you deselect the option to update you display driver from windows update and contact Microsoft support about the problem concerning the driver issue .
Jul 18, 2011 | Computers & Internet
When i switch on my acer aspire 5735 i see a blue screen informing me that windows is updating 3 of 3 updates but nothing happens as the screen just hangs for hours? Thanks
i think your windows was updating itself but there is a problem with the update maybe you did not finish the update or the update file got corrupted. try if you can go safe mode that might fix the problem if still the same you need to reinstall your Windows.
if you are familiar with Windows installation there is an option there wherein you can repair your previous Windows installation. try that it might help before reinstalling windows.
Apr 14, 2011 | Acer Aspire 5735 Notebook
MY LAPTOP WENT OFF DURING UPDATES NOW IT WONT FINISH LOADING, it comes up update 3 of 3 then restarts and says same again keeps doing it not letting me in to lap top anymore seems stuck on updates
Hold F8 while booting to go into safe mode, or last known good configuration. Then, preform the update from there, and that should fix your problem.
Feb 28, 2011 | Acer Computers & Internet
I want to remove genuine microsoft software from my cumputer.
this error is displayed, when you use unlicensed windows operating system. Hence in order to avoid this problem, you need to purchase licensee version or reinstall the operating system and disable automatic updates.
Thank you Ramketh
Apr 01, 2009 | Microsoft Office Professional 2007 Full...
Cannot get out of Configurating updates: stage 3 of 3 screen
This is all I could find:
It's not only Windows Vista Service Pack 1 that isn't ready for general consumer availability. Some of the updates released on February 12, 2008, as a part of the Microsoft monthly patch cycle, have managed to effectively kill Windows Vista. Users are reporting that, following the introduction of the February 12 updates, Vista gets stuck at the finalization of the deployment of the updates displaying the message "Configuring Updates Stage 3 of 3 0% completes" and then entering
an infinite reboot loop. And there is absolutely no way out for the end users, because canceling the configuration process of the updates is a move equivalent to losing access to the operating system entirely. This will even happen in Safe Mode.
Microsoft has yet to officially respond to the issue, or to provide a resolve or at least a workaround. However, it does seem at this point that there is an issue with the deployment of the pre-requisite updates necessary for the smooth installation of Windows Vista SP1. Namely, the problem resides in the Vista installation software. The fact of the matter is that end users will have to first update the Vista installation software and only then deploy the remaining February 12 updates and only at the end Vista SP1 RTM.
If you are stuck watching the "Configuring Updates Stage 3 of 3 0% complete Do not turn off Computer" and in the endless reboot loop, then stop the cycle and boot from the Vista media. You will need to "Repair your computer," so select your Vista installation and restore it to a point before the deployment of the updates. After gaining back access to your operating system, you will have to install the service stack update, namely Update for Windows Vista (KB937287). Deploy this update before any other on your Vista, and only then install the rest. At this point in time, you should experience no more problems.
"Update 937287 is a prerequisite package that contains updates to the Windows Vista installation software. The installation software is the component that handles the installation and the removal of software updates, language packs, optional Windows features, and service packs. Update 937287 is necessary to successfully install and to remove Windows Vista SP1 on all versions of Windows Vista," Microsoft revealed.
Dec 18, 2008 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
