what u actually want to do and what kind of note book ur using.. give model and brand of that maybe u dont have proper driver for that or try to connect it with pc first. regards,
This problem should occur only when the camera is not connected to the camera connecting slot properly.So, if you can open the full case just re-insert the camera.You can clean it with the soft cloth or cotton.Good luck
Try to go to the camera settings of your phone and try some adjustments or try to update the soft your phones camera, but if it doesn't work maybe your cellphone camera has a hardware problem.
JUST safely open ur mobile
open that side where camera is adjusted clean the wirings with the help of toothbrush & petrol put the camera at its place every point of camera should be touch its wiring ur camera will work if u r satisfied with my answer then pls vote me
open ur mobile carefully
now open that area where camera is adjusted now on copper wiring clean that wiring with a toothbrush & petrol i m sure that ur camera will work because i hv done it before & also adjust carefully but tightly the camera may be any wire is not adjusting & ur phone is arising problem SO NOW ENJOY
The Where its usually found in the front of the laptop or on the right side, its usually marked SD reader, The How is: you insert the camera card with the copper connection facing down. some of the older model laptops only come with SD readers for cell phones and video cameras not like now that they come with every type of card readers
go to ur camera options and then take a look at it and adjust the camera lens like day option , night mode etc...... i hope ur problem will get solved.
