Question about Jeep Liberty RB4 Navigation, AM/FM, CD, With CD Changer Controls
06 Rubi, R&I factory head unit, new unit has BASS loss
My previous head unit was swapped out of an 05 KJ with premium sound when I bought the 06 Rubi. I wanted the 6 disc changer. After a VERY dust wheelin trip, the changer would not release the CDs.
I took it in, they replaced the head unit, and the BASS was significantly diminished. It sounded tinny. I told them, they replaced it again, and it still sounds tinny.
I've checked, all speakers are functioning. Fuse OK to sub woofer.
If adjusted with Bass +8, Treble -3-5, fade +R4, it's tolerable, but not what it was.
On the previous unit I was set at Bass+4-5, Treb +2 and bal & fade at 0.
Can you offer suggestions? My dealership is doing all they can but there seems to be a gremlin in the works.
Is there a differenc in the units between the 05 Libby Ltd w/ Prem sound & 6 disc changer and the 06 Rubicon, it originally came with a single disc player but the one from the Liberty was moved into it when I traded it in.
Any help you can offer would be greatly appreciated.
SOURCE: 1998 jeep grand cherokee volume on factory radio not working
cut the telephone wire and see if the volume comes on
Posted on Mar 11, 2008
  • 3 Answers
SOURCE: CD "disc error" in Jeep Grand Cherokee
BE SURE THE CD THAT CAUSED THE PROB DIDNT HAVE ANY TYPE OF STICK ON LABEL THAT MAY OF COME OFF INSIDE, ALSO IVE SEEN CHILDREN PUT COINS IN THE CD SLOT IF YOU HAVE CHILDREN. MAY WANT TO TRY A CD LENS CLEANING DISK PROB FIND AT RADIO SHACK OR BEST BUY TYPE STORE.
Posted on Nov 11, 2008
SOURCE: Radio has power and clock works but no sound. I
while waiting for your response I managed to pull radio and discovered a loose connection. Works fine now.
Posted on Jan 21, 2010
  • 3 Answers
SOURCE: 2006 Jeep Rubicon Wrangler Speaker Wiring Diagram
I just installed a new 6" bose base speaker in my 2006 rubicon unlimited center console. first 2 pins one is + other is - 3rd pin with a missing pin is another hot. + are on same side. next two pins are front left speaker. then the right front. then the left rear then the right rear.
Harry
Posted on Mar 24, 2010
duane_wong
  • 6826 Answers
SOURCE: Cracked Cylinder Head
I'd say moderately difficult: here are the instructions for replacing the head on a 2001 Jeep Cherokee Sport with 4.0 L engine:
REMOVAL & INSTALLATION 4.0L Engines
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Crankcase Ventilation (CCV) hoses
    • Air cleaner assembly
    • Accelerator cable
    • Cruise control cable, if equipped
    • Transmission cable, if equipped
    • Control cable bracket
    • Valve cover
    NOTE: Keep valvetrain components in order for reassembly.
    • Rocker arms
    • Pushrods
    • Accessory drive belt
    • A/C compressor and bracket, if equipped
    • Power steering pump and bracket, if equipped
    • Fuel line
    • Combination manifold
    • Thermostat housing coolant hoses
    • Spark plugs
    • Engine Coolant Temperature (ECT) sensor connector
    • Cylinder head
    To install: WARNING
    Cylinder head bolts may only be reused one time. If reusing a cylinder head bolt, place a paint mark on the bolt after installation. If a cylinder head bolt has a paint mark, discard it and use a new bolt. NOTE: Refer to Section 1 of this manual for the cylinder head torque sequence illustration. The illustration is located after the Torque Specification Chart.
  4. Install the cylinder head with a new gasket. Coat the threads of bolt No. 11 with Loctite® F 592 sealant. CAUTION
    During the final tightening sequence, bolt No. 11 will be tightened to a lower torque value than the rest of the bolts. Do not overtighten bolt No. 11.
  5. Tighten the cylinder head bolts, in sequence, as follows:
    1. Step 1: 22 ft. lbs. (30 Nm)
    2. Step 2: 45 ft. lbs. (61 Nm)
    3. Step 3: 45 ft. lbs. (61 Nm)
    4. Step 4: Bolts 1–10 to 110 ft. lbs. (149 Nm)
    5. Step 5: Bolt 11 to 100 ft. lbs. (136 Nm)
    6. Step 6: Bolts 12–14 to 110 ft. lbs. (149 Nm)
    7. Step 7: Repeat steps 4, 5 and 6
  6. Install or connect the following:
    • ECT sensor connector
    • Spark plugs
    • Fuel line
    • Pushrods and rocker arms in their original positions
    • Valve cover
    • Accelerator cable
    • CCV hoses
  7. Fill the cooling system.
  8. Start the engine and check for leaks.
Posted on Jul 19, 2010
Can you replace a stock amp with a after market amp without rewiring speaker 2001 sport track
It depends on whether you have the standard audio system or a premium sound system. The standard system has no factory amplifier, the premium system has a factory amp and some other gimmicks that are hard to interface with. A proper OEM amplifier upgrade will require changing the factory speakers with stronger replacements, as well as adapting the factory head unit output to a signal your new amplifier will like. More often than not, it is more economical and better sounding to just change the factory speakers and run the replacements off your factory system. To drastically improve the sound system, it is more effective to just change everything.
Dec 23, 2014 | 2001 Ford Explorer Sport
How do I get map updates for Nextar Q4-03?
Someone told me that Tom-Tom took Nextar over and were providing support, but I could not find anything that showed that was true on their site.
I am at a loss too.
Mar 16, 2012 | Nextar 43LT 43NT Q4 Q4-01 Q4-03 Q4-04...
Blaupunkt Laguna CD35
No! What speakers have you bought?
May 23, 2017 | Blaupunkt LAGUNA CD35 AM/FM/CD RECEIVER
My daughter has a 90 Thunderbird that had an original premium sound package. The stereo went kaput and she bought an after market replacement. I went to install it for her and unfortunately opened up a...
These cars have a factory amp system that will not operate correctly with an aftermarket stereo. You have two choices. You can either run new wires to the speakers your self which would bypass the factory amp. Or you can order the premium sound system Interface here http://www.myinstallkit.com/FORD/1990%20(90)%20FORD%20THUNDERBIRD%20Radio%20-%20Stereo%20Installation%20Kit.htm scroll about half way down the page.
Jan 25, 2011 | 1990 Ford Thunderbird
I've got a 1999 ford expedition with the Mach radio system in it and it does not have any bass playing thru the front or back speakers and i've changed out the factory amp thats in the back where the sub...
does the new amp you have have a hpf setting if so check to see if thats on, turn off the x-over so it will play both lpf and hpf, bass and treble. are all the speakers wired to the amp aswell, this is the only thing that would stop bass other than the head units settings.
Jun 21, 2010 | 1998 Ford Expedition
BOSS BASS 600 - No Sound .
ITS BEST TO HAVE A SOLID REMOTE WIRE WITHOUT NE SPLICES WAT SO EVER
Feb 08, 2010 | Boss AUDIO SYSTEMS BASS600 Car Audio...
How can i unlock my garmin nuvi 200. what steps do i have to do to access my garmin.i bought my garmin from a friend who got it at a pawnshop.and its asking me for a pin that i do not have.can you help me?
Since you bought the device used, it's likely the previous owner did not clear the passwords and data. Short of tracking down the previous owner, there is no way to unlock the unit without doing a factory reset. Here's a guide to reset the Garmin GPS units to their original factory settings.
http://www.mydigitallife.info/2009/06/09/how-to-reset-garmin-nuvi-gps-device-access-maintenance-mode/
Dec 31, 2009 | Garmin nuvi® 200 Car GPS Receiver
Jensen JMP 50 sounds like I am in a tunnel or well.
Have you powered up the speakers have you checked the sound drivers?? but remember the sound of the Jensen JMP-50s is a bit hollow and lacking in bass, and the speakers do lack bass and treble controls, which can often be found in other speakers in the same price range.
Aug 18, 2008 | Jensen JMP-50 Computer Speakers
Cd won't eject
I've had this happen to me twice now. Once on an 05 KJ, next on an 06 Rubi. Both times 6 disc changer. I've had to take it in to the dealership for warranty replacement of the unit, they then return my CDs. The last time it happened was after a particularly dusty wheelin' trip. This time when they swapped it out, the bass is completely **** up with no solution in sight. If you're out of warranty, I suppose you could try tearing into it to get it out, but that would be risky at best.
May 18, 2008 | Jeep Radios: Genuine Am/Fm/Cd with 3 band...
Car Audio & Video Logo
66 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
