Question about T-Mobile Dash Smartphone
HTC DASH, No Voice Dialing
I have a HTC DASH, the owner's manual and the features listed on the box in which the telephone was packaged indicate the availability of voice dial feature. However, the menu item for voice dialing is not present as the instructions indicate. I tried hard reset, but to no avail. I tried to update firmware from HTC website, but my telephone serial number had no updates! I would appreciate your help!
Thank you,
Sam
2 Suggested Answers
  • 13 Answers
SOURCE: voice command button
Hi Ronnierat322,
Voice Commands:
The voice command hotkey is the "Home" key. To start using voice commands, press and hold the Home key until you hear a beep. Say "Help" and you should get a list of available commands and how to use them.
Media Player:
While watching a video, press the zero key to switch to full screen mode. Please see the link below for additional details on this:
http://www.fixya.com/support/t1104583-voice_command_button
I hope these help.
Please let us know how things go!
Thanks,
Jonathan
Posted on Oct 07, 2008
How can I setup forward call to my cel from VTECH CS6649-2
Call forwarding typically can redirect incoming calls to any other domestic telephone number, but the owner of the forwarded line must pay any toll charges for forwarded calls. Call forwarding is often enabled by dialing *72 followed by the telephone number to which calls should be forwarded. Once someone answers, call forwarding is in effect. If no one answers or the line is busy, the dialing sequence must be repeated to effect call forwarding. Call forwarding is disabled by dialing *73. This feature requires a subscription from the telephone company. Also available in some areas is Remote Access to call forwarding, which permit the control over call forwarding from telephones other than the subscriber's telephone. VOIP and cable telephone systems also often allow call forwarding to be set up and directed via their web portals. https://en.wikipedia.org/wiki/Call_forwarding
Jul 14, 2015 | Vtech CS6649-2 Digital Answering System,...
Lost manual . How do I get it to ask me who I want to call?
Voice dialing with the Explorer 220:
With the headset on, press the call control (answer) button for around 2 seconds to activate the voice dialing. This should prompt your phone and you should typically hear "say a command", then you can say, for instance, "call home". It will then confirm the command by saying "did you say call home?" And when you answer "yes", it should start dialing.
However, just remember that to use voice-activated dialing, your phone and cellular service must be capable of voice-dialing and this feature must be enabled on your phone. See your Bluetooth phone manual for instructions. Also, here is a link below for the Explorer 200 series user guide.
http://www.headsetsdirect.com/pdf/explorer230_ug_en.pdf
Aug 15, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
HTC Hero voice dialer does not recognize my
The Hero's voice dialer is a piece of ****. I would not use it at all. It defeats the purpose of voice dialing if you actually have to look at the phone to confirm who you want to dial.
I would see if there is another app that can do voice dialing that is better. I cannot give you any advice on that, since I don't use voice dialing.
Good luck.
Jan 29, 2010 | HTC Hero Smartphone
Voice dialing does not work at all. I press the
Your question gives insufficient information regarding which call button you're referring to, and no information about which country you're in so I'll have to stab around a bit and hope to hit the spot..
If you're asking why doesn't Bluetooth voice dialling work, then the answer is simple and really annoying: The Hero does not support it. Some folks claim it's just because it's not yet been added to the Android operating system, but I was told by HTC and T-Mobile tech experts that the phone does not support it at the basic hardware level. I don't trust the latter argument as there's now a few folks who claim to have transferred the application into the Hero by copying the files from a different HTC model (scroll down to post #44 onwards). I haven't been able to test this as I sent my Hero back when I discovered the lack of Bluetooth voice dialling. Android 2.0 *might* have it according to some, but the Android 2.0 website does not list it as a feature. HTC have not yet released their version of Android 2.0 yet so it's a case of wait 'n see.If you're with T-Mobile then the delay will be even longer as they'll need to tweak HTC's version of Google's Android 2.0 into a T-Mobile G2 variant <rolls eyes>. My understanding is that it will still be absent though.
If you're in North America, then the Hero already has voice dialling...sort of. Holding down the call key for a couple of seconds on the phone activates it. But you'll first need to touch the phone to wake it up, activate the voice dialling and then manually transfer the call to your headset. Utterly useless, and totally illegal in the many places where it's illegal to touch the phone whilst driving. On some networks the feature seems to be disabled and it does not work at all on UK/European models of the Hero.
There is another way to get voice dialling, but I'm unclear as to whether it will work via a Bluetooth headset: basically you install Google Voice onto your phone which allows you to search your contacts by voice command. Currently it's available only to those who reside in the USA.
Hopefully I've answered your question in which case I'd ask that you return the favour by rating my answer. If not, then please add additional relevant details and I'll try to improve upon my answer for you.
Jan 06, 2010 | HTC Hero Smartphone
Dont know how to program
The headset doesn't 'do commands', it only communicates your voice with your telephone. If you telephone is equipped with hands-free dialing, then you can hands-free dial through the headset. You can only use features which were originally installed on your phone through the headset. Please advise if this answers your question.
Dec 12, 2009 | Jabra BT125 Headset
Uniden dect 6.0 caller id light wiil not go out
I am not aware of any Uniden phone that has a "Caller ID" light. If you are talking about the small red LED on the top of the handset, that is a voice mail indicator and can be triggered by either a voice mail being held by your telephone service provider (Called Call Notes by some of the "bell" companies) or an unheard message on the telephones internal answering machine. Most of the time this is due to a voice mail on your service provider. If you don't think you have Voice Mail from your telephone service provider, call them and make sure, now days they include it with a bunch of other features without you ever asking for it. If you do not have voice mail through your telephone provider and there are no new messages on your answering machine, follow the Reset VMWI indicator procedures in your owners manual availible at http://www.uniden.com/index/manuals_results.cfm?cat+1
Apr 25, 2009 | Uniden DECT 6.0 Cordless Telephone...
How the heck do I set up voice dialing for hands free on my LG Vu
Go to "TOOLS" in the folder file, then voice command. Go to this link to down load the full manual. Then learn the voice commands that you may use.
http://www.phonedog.com/cell-phone-research/lg-vu-cu920_user-manual.aspx
Ron P
Jan 05, 2009 | LG Vu CU920 Cellular Phone
T-Mobile Dash Smartphone Logo
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
