Question about BenQ MP610 Multimedia Projector
BenQ MP610 Multimedia Projector Problem
The Power, Temp, and Lamp lights are yellow. I replaced the bulb, but they are still yellow. Any suggestions? This is a fairly new machine.
  • kmatt1111 Jan 02, 2009
    The situation as described above is the same for my MP610. Per the advised solution: The machine won't start, so resetting the lamp counter is impossible. It just sits there stupidly with its three lights on. The door switch is OK and is working correctly when the door is applied. The manual does not have a scenario for this problem, so it is no help. Why is this happening?!?
  • 4,234 Answers
I don't have the manual on this one, but in general if the lights indicated that the lamp needed to be changed because of hours of use, then until the lamp hours have been reset, the lights will remain. The owner's manual should have the procedure for resetting the lamp hours. Try that and update this if you still have a problem. Also, check to be sure that the lamp access door is closed completely. There are safety switches that get activated when the door is not installed correctly.
Dan
Posted on Sep 25, 2008
The projecter was locked and i had forgot my pasword what i want to do
Posted on Aug 02, 2011
HOW DO I CHANGE THE BULB IN A MP610 PROJECTOR
You need a smallish phillips head screw driver. Disconnect any power cords.Turn the projector upside down with the front facing you. On the back there is a 3" or so cover secured with one small screw. Remove the screw and the cover. You will see the lamp assembly. On the right is a white cable connection. Disconnect it. On the left is one screw securing the lamp assembly. Unscrew that, then lift the lamp assembly out of the projector housing. Now your options are to replace just the lamp or the whole lamp assembly.
Sep 25, 2011 | BenQ MP610 Multimedia Projector
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
The fuse has burned out in my projector benq MP610. So I opened the projector to replace it : same result. I verified, the lamp is also burned out. Do you think the burned out lamp can make the fuse to...
before a lamp blows it draws more current than it usually uses, but since it uses dc, it couldn't blow the ac fuse. but if the regulators on the ballast or power supply were bad, it would blow the lamp and draw ac power, possibly blowing the fuse.
Dec 02, 2009 | BenQ MP610 Multimedia Projector
Benq Projector MP721 stops illuminating after about 1 minute on. The lights are as follows: Power: Off, Temp: Red, Lamp: Green. Shortly after the projector shuts off. Thoughts?? My assumption is that the...
it might be dusty enough to hold in the heat. it needs a good cleaning. use canned air. if you still have an issue, the fans might be running too slow or the thermister (temp sensor) may be faulty. sometimes if it gets too hot in there, the thermister needs to be replaced, too.
Sep 11, 2009 | BenQ MP610 Multimedia Projector
How do you open a BENQ MP610 projector to replace the light? What tool do you use? Thanks Marty
I just replaced my lamp for the same beamer. Took me a while to figure out how, but if you know how, it is easy. Turn the beamer on its back. In the middle, you will see a black rubber (small), it covers a hole and a screw is in the whole. Pull the small bblack rubber out. Unscrew the screw. A small cover will come loose. And there is the lamp, You have to pull out the power cable, and than only one little screw that mounts the lamp to the inside of the beamer.
It's easy!
Hope you will succeed,
Ojnoka
May 23, 2009 | BenQ MP610 Multimedia Projector
Benq mp610
I replaced my lamp on my Projector MP510 after the projector shut down. I followed the instructions in the book to reset the projector but the projector shuts down all the time. Please can you help me HARRY
Sep 14, 2008 | BenQ MP610 Multimedia Projector
Benq mp6100
If this problem happen with a particular laptop then I suggest that you you change the setting of the laptop you are using. Go to Start=>Control Panel=>Performance and Maintenance=>Power OPtion=>Power Option Propreties=(click on Hibernation Tab and uncheck Hibernation box).
While on the Power Option check the time on the SYSTEM HIBERNATION.
Good luck
Dec 25, 2007 | BenQ MP610 Multimedia Projector
BenQ MP610 Multimedia Projector Logo
590 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
