Question about MSI 945GM2 H-F (816909015911) Motherboard
I want to install RHEL3.0 in SATA DeskStart HD using MSI SATA MB, but not detecting at OS installation time. HOW i can detect, Pls help me!!!!
I am using a SATA HD in MSI SATA (non-RAID) suport MB. When i am going to install Red Hat Enterprise Linux 3, the HD driver is not detecting/suporting. How can i detect HD and format that (DeskStart). Please help me!!!!
  • nickpower
    nickpower May 11, 2010
    I am not a linux master but from what i can tell you might need to use a newer version. Did you ever consider ubuntu? I messed around with it a little very easy Distro to get started with Linux.
  • 4 Answers
You need to create a space for which to install Linux. That likely means resizing Windows. Partition Magic is a good Windows utility to accomplish this, although there is a Linux version called Gaprtedthat will do essentially the same thing. You download the Gparted live cd, burn to disk, and run it from your computer. You must go into "setup" and set your Bios to boot from CDROM before booting the Hard Drive. Once booted, follow the on screen instructions. Resize Windows, (but NOT before a thorough defrag of your Windows drive), and create a "blank space" for Linux. Afterward, boot your Linux distro, (RedHat 9 was a great distro, but a newer version of a Red Hat based distro would serve you better, sayCentOS or Fedora Core), and follow the online instructions. Good Luck!
Posted on Aug 22, 2009
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
I tried to install SATA Hard Disc to MSI PT8 Neo-V Mother Board. But Even AMIBios Setup, it could not seen and when I try to install the windows, it tells no hard drive found.
cek our bios setup
1. is that addon card set to SATA or RAID?, SAT the set should be!
2. Broken? (maybe the cable not connect, power cable is bad or something else like, try to hear the sound working harddisk, teh sound because the HD's motor is working)
3. this time, the HD is very big enough, but the software not followed yet, so maybe your BIOS need to be upgrade, i dont know. try to flash it
at last, the HD only display detect when u boot the CPU. at BIOS is not display detect.
that my experience
sory if not helping
Sep 29, 2009 | MSI PT8 Neo-V Motherboard
HI i m posting the same problem onceagain with the trouble shooti
You could try flashing to the latest bios and disabling SATA RAID, disabling IDEs including bus master if u dont use any.
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Asus motherboard cannot detect Seagate SATA drive
Does your internal speaker beeps or stops telling you there is no hd detection?
Try to put another hd.
If you are using Windows reinstall it.
Does the red light blinks
CHECK out the power chord to hd and all power connections from psu
Dec 11, 2008 | ASUS A8N-E Motherboard
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
SATA's compatibility , motherboard update?
Hi k439,
Keep in mind that all serial ATA SATA hard disk drives are seen in the main bios menu as a Primary Master drive. When you load the bios you should see the SATA 320GB drive in the main menu, Standard CMOS Features. If you do not than the onboard SATA controller is defective. This can not be repaired. Only a motherboard replacement will fix this issue. You can go to MSI's web site below & allow MSI to check you're system for the latest bios upgrade. Follow their online instructions & update you're bios file but this will not fix you're onboard SATA controller. Click this link to MSI Live Update link: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
Sorry k439
Mike
Aug 16, 2008 | MSI PM8M-V Motherboard
MSI 945GM2 H-F (816909015911) Motherboard Logo
121 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
