Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Correct temperature for freezer & fridge
We recently lost power for 12 days and now that it is back on, I don't know what temperature the freezer and refrigerator should be set on to be correct.  I have a sub zero 650 top/bottom and a sub zero side by side.
thanks.
    President:
  • 1,462 Answers
Fridge should be about +4degC and freezer about -18degC
Posted on Sep 25, 2008
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Just bought a Dometic DM2862 fridge. Freezer on goes down to 12 deg. and lower unit down to 38 deg., but during day the temps are: freezer - 22 deg. and lower - 44 deg. Is this normal? Can I fix this?
While there is some fluctuations in temperature in Dometics from night and day, but it is usally the reverse of what you state. Warmer in the day time when the unit is opened more. I would check the temperature settings and if they are correct then check the thermostat.
Aug 31, 2011 | Dometic RM2652 Refrigerator
We lost power last night and it came back on our digital display onthe fridge just has one dash and will not allow me to set temperatures
When the freezer is below -12 degrees, you will not be able to set the temperature.
Should be ok after a period of up to 3 hours.
Hope this helps
Sep 29, 2009 | Samsung Refrigerators
Electrolux frost free fridge freezer
i have the same fridge freezer and the same problem and have no manual can any 1 explain thank you
Mar 31, 2009 | Electrolux Refrigerators
Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Oct 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Refrigerator will not cool
no there a is nothing you can do, they gonna change a card, and charge for the card and the job,now check for waranties maybe the card is on waranty...good luck
Aug 10, 2006 | Samsung RB2155 Bottom Freezer Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,331 people viewed this question
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ACME Sub Zero...
ACME Sub Zero...
Gere knutson
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
