Question about Epson Stylus Pro 4800 InkJet Printer
Error message after taking a jammed piece of paper from the print, there is a flashing Error light and i can't do anything.... i've tried unplugging and plugging. any other ideas???
  • Nick Sharp May 11, 2010
    irshval,
    when you removed the paper was it ripped and if so did you get all of the paper out.
    ElApe
  • 33 Answers
Which lights are flashing?
Posted on Nov 19, 2008
FS-3900DN rear unit paper jam
Hello, Power down the unit.Unplug power from wall. Power back up, if the error still happens, there is a small piece of paper somewhere, take toner out and look, or pull down back cover and look in there.
May 22, 2014 | Kyocera FS Office Equipment & Supplies
Error message paper empty free service
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 21, 2009 | Samsung CLP-510 Laser Printer
Dead Canon Printer MX310
Reset the printer by turning it off, then turn it back on.
if this doesn't solve the problem theres probably a paper jam, even a very small part of paper can cause the jam or it can be caused by pretty much anything thats not supposed to get inside the printer.
here are my instructions for clearing paper jams:
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it byholding it with both hands and pulling firmly. The goal is to keep thepaper from tearing. If several pieces are jammed together, try pullingout the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Dothis step especially if the jam message comes up repeatedly without anyobvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner orink cartridge and paper trays, close any doors you opened and turn theprinter back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Loada piece of thick paper, for example photo paper and press the resumebutton (may be diffrent button on diffrent models) a few times to theprinter picks up the paper and puts it through the machine.
Here is what canon suggest:
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
If the paper tears and a piece remainsinside the machine, turn the machine off, open the Scanning Unit(Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step (1), all print jobs in queue are canceled. Reprint if necessary
Also, have a look at what other people have said/ done with the same problem:
http://www.fixya.com/support/t159885-error_code_6000
Jul 18, 2009 | Canon PIXMA MX310 All-In-One Printer
LSU error message
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Flashing E3 error code for a paper jam
I had the same problem with my mp 160, Error message was blinking. I tried to print but the printer would take 1/10 of the whole page and stop, even though rollers were moving. My solution for this was to take a piece of thin cardbord(I used a magazine cover), cut it in a size of A4, put it in printer, printed it and when the rollers start moving I forcebly pushed the cardboard through. Now it seems to work fine. Hope it does for you.
Mar 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Step
Step
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
Nov 07, 2008 | Copystar CS-1815 Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Epson Stylus Pro 4800 InkJet Printer Logo
67 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
