Question about IBM ThinkPad T40 2373 Notebook
T40 memory upgrade
I tried replacing my 512M with 1G now PC won't boot error c0000218
can't load hive (file) \system boot\system 32\config\software
or ots log or alternate. It is corrupt, absent or ot writable.
Removed new memory and still same error.
How can i RECOVER? Tried putting in bootable disk in cd and still same error
    Scholar:
  • 188 Answers
One of your memory slots may have gone bad. Try putting one memory card in one slot thaen the other. Let us know.
Posted on Sep 25, 2008
My Gateway file c0000218 registry failure the registry cannot load the hive /SystemRoot/System/32/Config/System or its log or alternate is. It is corrupt, absent or, not writable.
it sounds like you have a bad sector on the part of the hard drive containing this file. you need to let chkdsk complete the scan as it may be able to recover the corrupt file and isolate the bad sector so its not used again.
if this works backup the system as your hard drive may be failing.
Mar 09, 2012 | Gateway MT6821 Notebook
Windows xp service pack 3 i have the system mechanic pro, the was a message for me to upgrade the product as i have a subscription,i did the upgraded, rebooted the system and got the following message: A...
Can you boot into safe mode and load a system restore point?
font.f1 {font: 12.0px 'Lucida Grande'; color: #000000} --------------------------------------------
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jun 28, 2011 | Dell OptiPlex GX270 PC Desktop
C0000218 Registry file failure. Registry cannot
The hive file is the problem, it is low on honey. Put it back to where the bees can produce enough honey for your PC to recognize it. Compaq's are notorious for their love of honey, that is why it is showing it is missing. DO NOT simply put honey on a CD and insert. Will not work.
Feb 01, 2010 | Compaq Presario 5000 PC Desktop
Will not boot up past the message I describe below
You might reload your Operating System to correct this. Insert your Recovery disk into your drive, choose DVD as Boot Option, recover your OS.
Nov 22, 2009 | Sony VAIO VGN-FJ270/B Notebook
Packard bell versa e400
Hi
files in system32\config\ are missing or corrupt.
there is a back up stored by default at c:\windows\repair
you can copy the contents of windows\repair folder into system32\config\ and it should solve the problem, you can do it with the windows installation cd by using the recovery console.
Go into the repair folder enter the following commands in repair console
cd windows (press enter)
cd repair (press enter)
copy *.* c:\windows\system32\config\ (press enter)
files should be copied
type exit, quit or restart or reboot to restart the computer.
May 22, 2009 | Dell Inspiron B120 Notebook
STOP: C0000218 {Registry File Failure} The registry cannot load the hive (file):\System Root\System32\Config\SECURITY or its log or alternate. It is corrupt, absent, or not writable.
to fix the problem, you need the Installation cd, put it in, start the setup, and enter repair console when the first blue menu comes up.
In repair console, your going to have to copy the windows\repair directory to system32\config
to fix the problem.
After the files have been copyed, Well maybe might be better if you only copy the SECURITY file. so no login details get changed.
Then restart the pc and see if it worked. If not your going to have to perform a repair installation from the xp cd.
If you need more asistance, let me know. Good luck.
Mar 29, 2008 | Microsoft Windows Server Standard 2003 for...
Problem with pc
Here is the solution right from Microsoft.
SYMPTOMS
When you try to start or restart your Windows XP-based computer, you may receive one of the following error messages:
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
CAUSE
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
RESOLUTION
To resolve this issue, use one of the following methods.
Use the Recovery Console Tool
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console.
Determine if the file that is mentioned in the "Symptoms" section of this article is present, and if it is, rename it:
In Recovery Console, change to the c:\Windows folder.
Type cd sytem32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type ren software software.bak (instead of ren system system.bak ), and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
Oct 23, 2007 | Computers & Internet
IBM ThinkPad T40 2373 Notebook Logo
121 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
