I have netgear wgr614v9 if i try and log onto router 192.168.1.1 with user admin and password password or 1234 it rejects it
    Problem Solver:
  • 6 Answers
Your user id is "admin"
your password is "password"
Posted on Sep 25, 2008
How can i changed the password of my router?
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings. From the center screen, select your encryption type from under the Security Options heading If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don
Feb 18, 2011 | NetGear WGR614 Router
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
Require my username and password from netgear so i can connect to a wireless printer
If you haven't changed the default password (user admin and password as password, or if that doesn't work try 1234) try to log in with that, if that doesn't work you will need to reset the router to the factory settings to get in with the default user and password which is the above one. Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Jan 03, 2011 | NetGear RangeMax NEXT WNR834B Wireless...
Lost my netgear connection. i have two new laptops i was trying to hook up. called tech. support w/HP they told me to plug the router into my lap top and i cant use netgear now. can u help
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Dec 26, 2010 | NetGear Computers & Internet
Can not reset router , netgear wgr614v9 user name
Hello
First unplug router.Then hold reset button in for 30 seconds,button is usually in the back may need a pen tip or paper clip to hold it in.
Then plug back in.Try logging on using admin as username and password as password.
Nov 02, 2010 | NetGear Computers & Internet
How do you change a wireless password on a netgear router
You have to log in at the router's settings page using your browser, and locate at the Wireless Network (or WLan, or Wi-Fi) the security section. Here is located the password you are looking for.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Oct 28, 2010 | NetGear DG834G Router
How to connect a wireless router netgear without a cd
  1. If the wireless network passphrase is visible, review it and use it to log devices onto your network.
hope this helps
Sep 23, 2010 | NetGear WGR614 Wireless Router
Network KEy - Netgear
you may have to push a pen tip into the reset hole on the back of the router if you can't get passed the log in screen, assuming you have done this:-
The default username is admin and the password is either password or 1234. Try these before resetting the router.
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password
Sep 09, 2008 | NetGear WGT624 Wireless Router
Lost key for netgear GT834PN
Do one thin connect ethernet cable between ur router and laptop open internet explorer and tyoe in this address 192.168.0.1 and press enter user name and pssword admin and password in lower case press ok router page will open up then click wireless settings on the left and on the right side right at the bottom of the page u will find key1 as ur wep key
Jun 01, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
