Question about Palm Treo 650 Handheld
Treo 650 The keys light up but the screen is blank. I replaced the screen and that may be the problem. Do I need to do something special to turn it on?
  • 1 more comment
  • meccie Sep 28, 2008
    I found the answer already and fixed the PALM. One of the sites sugested reseatting the cable from the screene making sure it fits all the way int the connector which I am pleased to know it woorked.
    Thanks
  • jrsmillerlit Oct 06, 2008
    the phone will restart and shows the palm logo then the screen goes white but the keys light up
  • jeep_phreak Oct 11, 2008
    ok ok my 650 i have already replaced the screen once, and now i thought the screen went out on me. So i swapped screens and still the same thing my screens works on another 650 bot the other screen does not work on mine... heres the real kicker i can still use the touch screen to answer calls, to call people, and to get on realplayer... any ideas please let me know
Try a Zero Reset - but you will loose all your data
Posted on Sep 28, 2008
My Palm treo...will not dial out, or accept phone calls (with ringtone)! This happened all of a sudden,without me doing anything abnormal to the phone. Please advise! Sincerely, Tim McLinskey
You could try to turn the unit off completely, take the battery out, wait for few minutes and put them back and turn on to see anything better. This action helps to clear the memory of your unit.
If after you doing that problem still, i think you need the hard reset your Palm Treo. To do the hard reset, you need to back up all your data to the computer first, syns all contacts and files to your comp and perform the hard reset.( How to do hard reset could find in your manual)
In my experience, the palm treo is very sensitive handheld, the keys and touch screen easy to create the problem for you when you put your phone in the pocket with car keys or something. Try to avoid this.
Hope this will help.
Feb 07, 2011 | Palm Treo 650 Handheld
Tip
HOW TO PERFORM A HARD RESET ON Treo 650
Performing a hard reset on a Treo 650will erase everything on the smartphone. Most people do this because of trouble with the Treo 650's software. There are several key stages to performing a hard reset. Follow these steps to learn how to do it properly.
  1. HotSync the Treo 650 to your computer to ensure that you have all of your information backed up. You will lose everything on your Treo 650 with a hard reset.
  2. Step 2 Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset.
  3. Step 3 Let go of the red phone button when you see the Palm screen.
  4. Step 4 Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset.
  5. Step 5 Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone.
  6. Step 6 HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process.
on Sep 17, 2009 | Palm Treo 650 Handheld
Language settings
Bueno, trata lo siguente:
If you purchased the Treo in the U.S., you should have the English to Spanish option when you reset the phone. Just make sure to back up your data before resetting it.
Step2Press and hold down the red phone key on the right side of the Treo 650 keyboard until the Palm screen appears. This will begin the hard reset. Step 11Let go of the red phone button when you see the Palm screen. Step 2Read the screen prompt carefully. It will ask you to press the up arrow key to proceed with the hard reset or the down arrow key to abort. Press the up arrow to continue with the hard reset. Step 3Wait for the phone to reboot. When it comes back on, it will ask you to select a language and walk you through the same introductory screens you saw when you first got the phone. Step 4HotSync your Treo 650 to your computer. When prompted, select your old username to restore all of your contacts and information. This should complete the hard reset process. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
  • Do not forget to back up your data before performing the hard reset. If you don't, only the data from your last HotSync will be able to be recovered.
  • After performing a hard reset, install your applications one at a time to make sure each is in working order. Delete any applications that are not in working order, as those might have caused the need for the hard reset in the first place.
Buenas Suerte,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks,
Joe Diaz
Apr 22, 2009 | Palm Treo 650 Handheld
Screen not synched
try doing a warm reset with a blow dryer
Jan 29, 2009 | Palm Treo 650 Handheld
Treo 650
my treo 650 just turned of the light of the screen.thought it was only battery.i pulled out the battery then put it back again,the light is on and say palmOne with a bar loading.then the light was gone again.try to sign on but nothing does
Jun 24, 2008 | Palm Treo 650 Handheld
Frequent hanging of my new palm treo650
If it's new, it's under warranty, get a new one.
Also, if you have tons of add-ons, this can cause frequent hangs. Uninstall some of them.
May 25, 2008 | Palm Treo 650 Handheld
Treo 650 "Dead Screen"
Try plugging in your Treo as if you were charging it.
Then click the reset button in the back.
This should reset the charging mechanism inside.
See if the Treo starts to charge again after that by letting it sit for 1-2hrs.
Jan 04, 2008 | Palm Treo 650 Handheld
Palm treo screen freeze
check to see if any buttons or keys are stuck down.
If not, then you may have a damaged screen or cable that needs repair
Dec 05, 2007 | Palm Treo 650 Handheld
Treo 650 microphone turns off when screen goes blank
Hi
Have you gone under Preferences -> and disabling the auto keygaurd
there are 2 options
incoming calls received +
on a call
try disabling both these options and let me know what happens
Nov 20, 2007 | Palm Treo 650 Handheld
Deleting Outlook contacts
FileZ file utility lets you delete the AddressDB on your Treo Your best bet would probably be to wipe the Contacts database on your Treo 650, then re-sync. 1. Install FileZ on your Treo 650, Why? Because the Contacts DB is not accessible from the built-in system; you need this extra file manager to delete it. 2. Launch FileZ and find this item: AddressDB. 3. Tap on AddressDB to add a checkmark next to it. Hit Details. Hit Delete. 4. DON'T HOTSYNC YET! Just in case, export your Outlook Contacts and store in a safe place. You'll be syncing to a blank address DB on your 650, and although it shouldn't overwrite your Outlook data wwith the blank DB ... better safe than sorry. 5. Now you can HotSync to Outlook.
Sep 11, 2005 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
62 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
