Question about Whirlpool Duet GHW9150P Front Load Washer
Soap not emptied
New whirlpool aa 600 ran on delicate cycle at 30 degrees. The soap was still in the intray when the cycle was complete.
The soap tray has a plastic separator which has one position for liquid soap (the separator goes to the bottom of the tray).
It has a second position in which the separator leave a gap at the bottom so the powder can be flushed through.
I had put powder in the liquid setting and thus the soap did not get flushed into the washer.
Posted on Sep 26, 2008
Cleaning maxi-cosi cover
Hi
Fabric is designed to be removed for washing, either handwash or handwash / delicate cycle on washing machine is fine, maximum 30 degrees, ensure you use additional rinse and spin to completely remove all detergent residue as leftovers will dry and leave white marks.
Dec 27, 2013 | Maxi-Cosi CabrioFix (Black Reflection)...
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
Won't complete normal cycle, but will complete heavy duty normal cycle gives errors codes of "sd", and "f21". have cleaned trap, and it works for next cycle, then errors out again. But Heavy duty works...
GOOD NEWS
actually SD means SUDS, it maens that your using too much soap,
when you clean out the rap your cleaning out the rest of the soap,
anyway, if you cut way back on your soap, i usually sugest 1 tablespoon for these models works just fine
try one empty load and no soap
watxh the suds appear in the wash cycle
remenber you bough this machine for water savingfs
1/6 the water 1/6 the soap
Oct 24, 2009 | Whirlpool WFW8500SR
I have a lot of black soot like substance that appeared in the drain, spray arms, and dripping out of the soap dispenser's. The heating element has a small damaged section. Can a bad heating element cause...
Has to do with the detergent you are using is not completely breaking down the food materials being removed from the dishes during washing. I ran the dishwasher empty through a pot and pans cycle with maximum options and some bleach, Cleaned it to like new condition and from now on I use a detergent that has bleach in it. Cascade has several different products to cover this.
Sep 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
The 2H (not 2h) comes up and then runs for 99 minutes Shu5315
first off never ever run bleach in the dish washer bleach eats the rubber gasket seal; between the tank and the base causing it to leak in to the base of the d/w. if you get a 2H and the d/w continues to run and never stop toy have a bad heater that is easly figured out by putting an amp clamp on a meter and putting the d/w in delicate economy and checking the amp draw on your wire with out heater on the draw is usually 2 to 3 amps when heater comes on the draw will be 12 to 14 amps in delicate economy the machine drains for 15 sec fills with water after 1.4 gallons are in the machine the heater will kick on and heat up the incomming water to 150 degrees if you dont have the draw on the line it is usually the flow through heater.
Aug 13, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Soap
Your soap is old. Get some fresh stuff, or use a liquid dw soap
Jul 24, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Leaks on Delicate but not on Normal.
Appears to have been the drain holes below the rubber drum flange. My wife cleaned in there for the first time after our speaking to a lowes sales person who owns one as well. When I monitored the next "delicate" load with the front panel off and after cleaning, there was no sign of water anywhere. Hope this was the solution. My wife also mentioned the loads (on delicate) came out damper than the norm but this time it was much drier. Wonder if delicate cycle may fill the washer higher than the normal cycle.
As a footnote we mentioned an occasional musty smell would occur and the same sales person said to not only leave the front door ajar but also open the soap drawer. When I checked the service manual I noticed the unit has a vent hose which vents into the soap drawer. All makes sense when you consider a front load is much tighter sealed than a top load.
Jun 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water Leaking From Calypso, Won't Drain Completely
the bag type device is an overflow and should never have "water"in it, but it will get suds if you are using the wrong type of soap.
you need to use "HE" soap as it is a non-sudsing soap and thats why you are getting suds leaking from your unit.
just run the rinse and spin cycle until the suds are gone. then use the right type of soap and it will work properly with no leaks.
Jan 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Not washing clothes
Sounds like you need a new timer.  Sorry.
Oct 14, 2007 | Zanussi IZ161S Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
227 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
