Question about HP LaserJet 1000 Printer
Hp laserjet 1000
My hp lj 1000 printer it continue moving paper pick-up tray
  • Anonymous Oct 10, 2008
    the feed tray continues to take papers and it does not print
  • roninkaoto Oct 22, 2008
    It is very similar, but its got nothing to do with the atmospheric
    conditions... in this case when I send a document to print, it starts
    taking papers one after another one, like four in a row, and normaly it
    stops in the third one or fourth one and no paper is printed and then
    pc and printer show a jammed paper... sometimes, there's not even paper
    in the rollers and paper comes out fine but no printing, it only prints
    whenever it wants to... like every ten paper jams.. I checked
    everything even reinstall the drivers and checked size and type of the
    paper properties and nothing... this sucks, it is the very first time
    this has happen to my trusty printer, I have to admit it, it is a damm
    good printer 'till now.. I have even reset it.. theres this hidden
    reset button beside the "usb" cable.. so if anyone knows how to fix
    this or what I'm doing wrong, please tell me... And something else, the
    paper tray stays up when the "printing" is finished, but it goes up and
    down for paper feeding... this sucks...
Dear sir / madam,
I have a printer of hp laserjet 1000 .
I want to install the driver of abov.
how can this possible by internet.
Posted on Oct 04, 2008
HP LaserJet 4250n Printerclearing paper path Questions
If this continually displays then either you have an actual paper jam in the printer that you have not found yet or a flag is broken/sensor has failed. Make sure you check the paper path that runs from the tray behind the MP tray assembly.There is a sensor in there that can be damaged.
Dec 02, 2015 | HP LJ 4250 Printer
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
Why my HP LJ 4100 is always taking envelopes from tray 1, even when I try to print from tray 2?
Check your feed rollers in tray 2. Sounds like they are worn and the paper cannot be pulled from tray 2 so it goes to tray 1
Sep 20, 2013 | HP LaserJet 4050 Printer
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
Paper won't fit into paper tray
Go to HP.com. Download the User Guide. It will explain how to do it.
Nov 20, 2009 | HP LaserJet 1000 Printer
Hp laserjet P4515n printer
you'll probably need a replacement paper tray.The sliders are fitted with small teeth to prevent them from moving.These teeth can break off meaning the paper size slider moves around too much and the paper sits back away from the feed roller and it doesn't get picked up correctly by the fed roller so resulting in a paper jam error
Oct 12, 2009 | HP Office Equipment & Supplies
What is message: 41.3 paper error ?
Hi there
41.3 on a lj 4+ is a paper Feed related error normally caused by dirty or worn paper feed tyres if you are getting this error whilst feeding from the paper tray at the bottom of the printer stack a few sheets on the manual feed tray on the front if you dont get the error
clean all your feed wheels or order a service kit and replacement replacement tyres
Regards AL "alstech"
Jun 07, 2009 | HP LaserJet 4 plus Printer
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual:
http://home.comcast.net/~wannabeyote/hp-lj-4-5-m-n-plus.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | HP LaserJet 4 plus Printer
Settings in HP Printer LJ 4100.
The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper.
Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal.
The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page:
MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT.
The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2.
The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray.
Or the arms on the tray that operate the switches are not moving properly.
You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps.
Mar 23, 2009 | HP LaserJet 4100n Printer
HP laserjet P2015D , JAM LED in a solid state ??
Dear gentlemen,
Hope this helps you sort out the problem. Please check paper jammed pieces of paper remains from paper in to out paper path. Check if the paper is properly picked-up, else check rubber roller pick-up and the solinoid motors that control to fed on and off the tray to engage pick-up. Check paper path sensors if possible. If you can determine when is the paper Jam happens please advice. Other means you can also refer your manual and machine diagnostic menu which part of the operation the paper will jam.
Best regards,
Rosener Guyano
Jan 10, 2008 | HP LaserJet P2015dn Printer
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
199 people viewed this question
Ben Johnson
