Question about Canon Office Equipment & Supplies
Ink cartridge carrier slids very fast to the right and error notice reports ink cartridges not in properly which i have checked many times
Thank you but it seems to be OK now. After trying numerous times I took out the cartridge yet again and pushed it back down very hard and it seems to have done the trick! I did wet the end with my finger, which a friend of mine told me to do. I then followed instructions in the manual (which I had previously tried unsuccessfully) and this time it worked. Hopefully it will now print with no further problems.
Thank you for enquiring again.
**** Carroll
Posted on Sep 26, 2008
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    The printer error is Oxc18a0005 it said ink system failor. how can i solve it
    Issue One of the following ink system error codes displays on the printer touch screen display: 0xc18xxxxx or 0xc19xxxxx . Solution Follow the steps below to resolve this issue.
    1. Press the On button to turn the printer off.
    2. Unplug the power cord from the back of the printer.
    3. Remove all the ink cartridges.
    4. Wait two minutes.
    5. Plug the power cord into the back of the printer.
    6. Press the On button to turn the printer on.
    7. Install the ink cartridges when prompted.
    If the error code does not display, the issue is resolved. If the error codes still display on the front panel, service the printer.
    Jan 28, 2010 | HP Photosmart D7260 Printer
    Cartridge error 1203
    First of all, please verify each cartridge carrier has an ink cartridge :
    1. Check to make sure the left cartridge carrier contains a black or photo ink cartridge.
    2. Check to make sure the right carrier contains a color ink cartridge.
    3. Remove each cartridge and examine it to make sure the protective tape has been removed from the contacts and the print head.
    4. Replace each cartridge in the proper carrier.
    Step 2 :
    Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
    Wicking the Cartridge
    1. Ensure the printer is powered on.
    2. Lift the scanner unit.
    3. Open the cartridge latches and remove the cartridges from the carrier (Figure 1).
      Figure 1: Removing the Cartridges from the Printer
    5. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back (Figure 2).
      Figure 2: Proper Cleaning Direction
      new_note.jpg Note: Never wipe the cartridges from side to side, as this causes cross-contamination in color cartridges.
    Cleaning the Contacts
    1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge (Figure 3).
      Figure 3: Turning the Cartridge To View the Back Contacts
    3. Using a clean dry cloth, wipe the contacts in the direction shown (Figure 4), so that no dust or other contaminants are visible.
    4. new_note.jpg Note: Do not use the same cloth that was used to clean the cartridge nozzles. This may cause more contamination on the cartridge.
      Figure 4: Cleaning the Contacts on the Back of the Cartridge
    5. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
    6. Replace the cartridges in the carrier and close the scanner unit.
    7. Print the document again.
    8. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
    Dec 19, 2009 | Dell 924 All-in-One InkJet Printer
    HP photosmart C6188 Ink Failiure System (error 0xc18a0207)
    IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
    Wait two minutes.
    If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
    Nov 15, 2008 | HP Photosmart 3210 Printer
    Hp C5100 printer error code oxc18a0001
    Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution Press the On button to turn the printer off.
    Wait two minutes.
    If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer. Please let me know if the issue is not resolve so that i can check for a possible solution for that. Thank you so much.
    Nov 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
    Error Code
    That's absolutely correct. The exact error message on the printer says "Ink System Failure. Error 0xc05d0281."You need a new printer for that kind of error. Actually there 3 different errors that you may encounter when installing brand new ink cartridges. The error that starts with 0xc18 and 0xc19, we can still recover the printer for that but only once. If the T/S is already done and was not able to resolve the problem, then that's the time that the printer needs to be replaced. For error 0xc05, ther only solution is to replace the printer. It means that the ink system has already been failed and cannot be recovered.
    Jiffy Epe
    HP Technical Support Representative
    Aug 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
    What is error 0xc18a010a on for the 8250 hp printer
    If you are not using HP ink cartridges you may have trouble. I was using Rapid Refill cartridges and had the same problem. I returned them and was told that a new chip has been installed in hp cartridges, so you need to make sure that the cartridges have this chip. Rapid Refill set me up and have not had any problems since.
    Aug 19, 2008 | HP Photosmart 8250 InkJet Printer
    Dell 810 giving Incompatible Ink Cartridge error message
    Hi try these steps
    STEP: Disconnect and Reconnect the Printer Power Supply
    Top of Form 1
    Bottom of Form 1
    Unplug the power cord from the wall socket.
    Disconnect the power supply from the back of the printer.
    Wait 15 seconds.
    Reconnect the power supply to the back of the printer.
    Plug the power cord back into the wall socket
    STEP: Clean the Contacts and Wick the Ink Cartridge
    Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back.
    Using a clean dry cloth, wipe the contacts so that no dust or other contaminants are visible
    STEP: Verify Each Cartridge Carrier Has an Ink Cartridge
    Let me know the status.
    Regards
    Jan 07, 2008 | Dell 810 All-In-One InkJet Printer
    Cartridge stall
    There could be 4 possibilities.
    1. Ink cartridges lids are open which is not allowing cartridges to move freely.
    2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
    3. Encoder strip is Dirty.
    4. Encoder strip is Out of position.
    Solution:
    1. Open the front cover and check if ink cartridges lids are properly snapped in.
    2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
    Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
    3. Cleaning the encoder strip:
    a. printer should be off and disconnected from power.
    b. open the front cover.
    c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
    d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
    e. Close the printer and try again to print.
    4. Repositioning the Encoder strip.
    a. Remove the power cord from the printer.
    b. Open the front cover.
    c. Gently slide the ink cartridge carrier to the middle of the printer.
    d. Gently move the top part of the printer belt to the right.
    e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
    g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
    h. Once the encoder strip has been re-seated, close the scanner lid.
    i. Re-connect the power cord to the printer and try again to print.
    Incorrect position of encoder strip
    Correct position of Encoder strip
    Hope it should fix the issue.
    Sep 04, 2007 | Dell 924 All-in-One InkJet Printer
    15 people viewed this question
    old marine
    old marine
