Question about LG Televison & Video
OTA Mode Our DVD Recorder has a DVD in it, when we turn it on it is showing OTA Mode in the display. We cant seem to get past this, we cant turn the DVD player on or get the DVD out. It makes a funny noise when it starts up which i guess is because there is a DVD in it? Can any one offer any suggestions? I have done the ususal things, pressing lots of buttons, powering off and on and nothing works.
    Sergeant:
    Habit-Forming:
  • 194 Answers
Any storms around? sounds like a power spike may have tanked it
Posted on Aug 01, 2017
SOURCE: panasonic dmres10 dvd recorder showing ' x hold '
This is the child lock feature, to stop unwanted use of the unit. Using your remote control, hold down 'enter' and 'return' until a message is displayed.
Posted on Jul 03, 2007
SOURCE: LG DR-4810 DVD Displays " PLEASE WAIT"
C113 10v 1000uF cap off an XFRMR in power supply board. Cooked and gone high esr. Replace with a 16v.
Posted on Nov 26, 2007
SOURCE: DVD Tray will not open
I purchased this unit back in Mid November to make DVD's of my kids old VHS tapes. To date I have probably have made 400 DVD's. Sunday we came home from being gone all day and the unit was locked up. I tried the reset button, unplugged the unit etc to no avail. I unplugged the unit all Sunday night and looked at it again on Monday morning. I was ready to take the unit back to Best Buy and the unit ejected the DVD and has worked for 2 days (Recorded another dozen DVD's). Tonight while reading the paper a message came on my monitor that there was a problem with the disk and instructed me to push the "enter" button which shut the unit off and was suppose to recover the disc. The recorder is now locked up again. A number of 000000's flashes accross the display and the unit constantly cycles off/on. So it is trying to recover but is obviously not being successful. I am going to try the same thing tonight. I am not sure if I have a bad set of blank DVD's. They are Sony -DVD R, same ones I have been using all along. I do remember having this "Error" message when I first started this project and I had to unplug the unit to resolve but it didn't lock up and I haven't had any issues until Sunday. Seems like something in the software is screwed up. It is frustrating that there doesn't seem to be a manual way to eject the disk??!!
Posted on Jan 16, 2008
SOURCE: Cyberhome 300 DVD Player: pal to ntsc mode?
Turn on your dvd player then press continuesly the stop buttom in the panel 10-15 seconds til the screen appears.
Posted on Apr 15, 2008
SOURCE: My dvd model is philips dvp 3005 and it is in standby mode
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi, I have a LG DR165 DVD Recorder. I somehow put the device into what seems to be a service mode, with HEX numbers. I can now boot my DVD Recorder, however the LCD display shows random letters and...
Issue On the logic IC processor due to overload static Cause power lost during initial Statut ..Unit need service ...Capacitor fail on Digit logic processor... Or unplug unit for several hour and try agant good luck
Sep 29, 2010 | Televison & Video
Ota upgrading software not progressing
See "Software update and system information" inthe user manual. For the RHT497H this is on page 27.
Apr 24, 2010 | LG Televison & Video
Video freezes on dazzle dvd recorder operating on win vista.
I suggest to you to uninstall your Instant DVD recorder program and then download and install this update version http://pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Plug-Ins/Instant+DVD+Recorder+Support/Download+Area/Drivers+-+Updates/IDVDR261.htm?mode=documents&Display=1
Checked also if your vista is 32 bit then download under 32 bit but if that is 64 bit then download for 64bit. Try again.
Sep 29, 2009 | Pinnacle Dazzle DVD Recorder
Command mode change
Pretty easy, Recorder shows DVD1 in display..OK Slide COMMAND MODE Switch to DVD1 on remote Control. This switch is located in lowe part of remote control and has 3 settings.
Jan 04, 2009 | Sony RDR-VX521 DVD Recorder/VCR
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
Insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Jul 04, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Please wait
try to clean loading sensors
Jun 03, 2007 | LG RH-4820 DVD Recorder
Televison & Video Logo
156 people viewed this question
Computer Repairing
Computer Repairing
