Question about Whirlpool Refrigerators
Everything is running but won't get cold. Not since the power outaged
My refer is hot both top in bottom.
  • tpearlis Sep 26, 2008
    What's the average cost to have refrigerant refill ?
  • 121 Answers
If everything is running both top and bottom then your low or out of refrigerant
Posted on Sep 25, 2008
  • Edward Boukater Sep 26, 2008
    It cost $10 to $20 per lb for R-134a, plus whatever your local contractor charges for service call. If your in the New Orleans area call me at 504-722-3946 I charge $50 service charge and $15 per lb. of R-134a refrigerant.
Water doesnt get hot unless you run the sink first then the wster on shower get boiling hot then ice cold showers a few weeks old
So you have 2 heating elements in your hot water heater. A top and a bottom. From the sounds of it your top element has went bad however they are only about $17 a piece new and it is recommended you replace both at the same time. Thats why it takes you long run to get hot water the top water heater water is still cold and long run gets to the bottom and gives you hot water.
Apr 03, 2015 | Home
Hotpoint refrigerator won't stop running
The temperature sensor could be at fault
Mar 26, 2013 | Refrigerators
On my GE GTH21SCXSS, top freezer bottom refer, the freezer and refrigerator settings are on the coldest settings and the freezer won't go below 15 degrees and the refer won't go below 43 degre
Do you see any ice buildup on the back panel of the freezer? You may need to remove the back panel to see if the coils are iced over. Post back your results.
Feb 10, 2013 | GE GTH21SCXSS Stainless Steel (21 cu ft)...
I moved my washer and didn't notice how the hoses were connected. Is the hot on top or bottom? Thanks
There should be markings on the washer near the inlet valve that will have a "H" or "C" for hot or cold. If not, hook the hoses up and run cold water only. If the water comes out hot, you will know that the hoses are crossed. It won't hurt anything to run the machine this way.
Sep 15, 2011 | Maytag PAV2300 Top Load Washer
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have an amana ASD2626hes side by side refer/freezer unti. REcently it soppted colling in the refer and the freezer was cold on the bottom only - top warm. I pulled the freezer inside coer - found the...
It could be either....
It is best to check and see if you are getting power to the fan...power to fan, the fan is power the board is bad...
Apr 23, 2011 | Amana Refrigerators
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Fridge hot, freezer holding coldness but not
check compressor operations. also display board can fail in power outages
Feb 12, 2010 | Refrigerators
We had a power outage and top half will not work
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Refrigerators
Kenmore Elite quietpak9 HE4T washer FH error code
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem.
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
