Question about Intel Motherboard
No display a long beep sound comes whenever i push a cabinet button and no display... i want to format my pc but there is no display pc is not working at all.
  • 75 Answers
Check whether your RAM is working properly.....Try to unplug it and plug it tightly....if the problem persist try replacing the RAM....
Posted on Sep 25, 2008
1 continues beep sound from cpu and no display on monitor
there is a chance of ram having problem.
if you are able to open the pc try to open it and clean the ram with eraser and the ram slot with soft brush
Dec 23, 2015 | Computers & Internet
No display problem for intel D865GSA board
What are you formatting ? Have you changed the RAM. Does tour system work in its original configuration ? You do not say what the pattern of the beeps is. Before the display disappears, is there a message sent to the screen ?
From the manual
http://download.intel.com/support/motherboards/desktop/d865gsa/sb/d5600601us.pdf
Whenever a recoverable error occurs during POST, the BIOS displays an error message
describing the problem (see Table 53). The BIOS also issues a beep code (one long
tone followed by two short tones) during POST if the video configuration fails (a faulty
video card or no card installed) or if an external ROM module does not properly
checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors,
usually consisting of one long tone followed by a series of short tones. For more
information on the beep codes issued, check the documentation for that external
device.
There are several POST routines that issue a POST terminal error and shut down the
system if they fail. Before shutting down the system, the terminal-error handler issues
a beep code signifying the test point error, writes the error to I/O port 80h, attempts
to initialize the video and writes the error in the upper left corner of the screen (using
both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to
the operating system.
18.April.2014
18.April.2014
Apr 18, 2014 | Intel 865G Motherboard
Dell 8200 beeps 10 times monitor won't come on says power saving mode
Hi
Remove the sound card and blow the slot with dry air to rid off dust.
Examine it to make sure nothing's damaged and fix it again.
Checkout the RAM's.Probably remove them,wipe the slots off dust and fix them again.Make sure they're well seated on their slots.
Feb 05, 2012 | Computers & Internet
Why is my ps3 160 gb not working.. the green light comes on. but takes 10s to come off. there is no yello light. maybe its the hdd . . . there is nothing showing on the screen
Hi there, try to do a hard reboot on your system. I suggest you have the system turned off, and when you power it up from the system itself hold the power button not just push it. It will beep and turn on but while you are holding the button it should beep beep again and turn back off continue to hold the button and it should boot up 1 more time. or you may have to let go of the button and hit it 1 more time, but it may help your situation
Feb 04, 2011 | Sony Playstation 3 (PS3) Console
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
3 beep sound coming
Open your chassis (cabinet) and look for the bios jumper on the motherboard. It is located near the SATA ports next to the Front Auxiliary Fan connector. Put the jumper in 2-3 to enable maintenance mode. This will allow you to enter bios settings. Then redo any changes that you had made, i.e. reset the memory configuration to auto and save the changes and exit.
Now replace the jumper in 1-2 position. Reboot. And your system will work fine.
Apr 16, 2008 | Intel D945GNT Motherboard
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
System Fault. No display nor beep sounds.
Here is suggestion: Disconnect the HDDs and other storage devices and then start your machine. If this does not isolate your problem. Try changing the keyboard. Hint: also make sure your motherboard is not touching the metal cabinet anywhere. If so it can cause serious damage to your system.
Sep 26, 2007 | Intel SE7520BD2 Motherboard
Freezing, clicking and beeping
Have you tried updating the firmware of your Zen V Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
I hope it won't keep freezing on you after the update.
Apr 08, 2007 | Creative Labs Zen Touch MP3 Player
Intel Motherboard Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
