LCD TV lamp indicator on and lamp doesn't fix problem
I have a sony lcd whos picture will go black and then come back on for 30 sec. or so what do u think this can be. i have been told a lamp or picture tube, and what is the estimated cost of repair
Posted on Nov 13, 2008
  • nmwilhite Nov 13, 2008
    i have a rca with no picture and makes a loud hi pitched sound what do u think this is?
  • 4,234 Answers
FIrst of all, make sure that the lamp door is secured properly. There are safety switches inside that will prevent the set from working properly if the doors are not closed fully. If there is a door for access to the fans, this too can be at fault. Try that first and update this if you are still having the problem.
Thanks,
Dan
Posted on Sep 25, 2008
I replaced the lamp in my Sony E50A10 and the tv still doesn't power up.The indicator flashes red.Any ideas?
if its the lamp indicator flashing its an issue with the lamp. If the lamp is new I would double check to see if its making contact completely when its slid in often the pins can get bent slightly. If it were the ballast the power indicator would blink 5 times.
Feb 09, 2013 | Sony Wega KDF E50A10 TV
Time light blinks 3 times tv does not turn on is it the lamp? and if so how do i fix it
This tv is a LCD tv?Yes.No projection lamp on a LCD tv.Blinking LED any lights,LED light have power indication word on it?Yes,that power supply board it is dead and the causes.
May 31, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
My Sony LCD rear projection tv model KDF-55WF655 won't come on. Instead the red lamp light comes on. What can I do ?
Red lamp light indicates that tv needs lamp replacement as existing lamp in tv is dead/ broke.
Lamp replacement procedure is written in user manual of tv.
Thanks.
Apr 28, 2011 | Sony Televison & Video
Kdf-e42a10 i have no power ,only red led 3 time flashing
3 times red light flashing indicates that lamp cover has not been fixed correctly in tv after lamp replacement. Please make sure lamp cover is fixed securely after lamp replacement.
Thanks.
Feb 05, 2011 | Sony KDF-E42A10 42 in. LCD Television
My Sony KDF-E60A20 tv is not working this morning my lamp indicator was flashing is this a problem i can fix myself or is a service technician needed?
you can fix by replaced your tv lamp only.mostly lamp number menstion on top side. if not found then tell service center only model number of your tv and get your Lamp. Lamp replacement way menstion in Lamp user manual.
Oct 19, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
The tv keeps turning itself on and off
Ur tv have a LED POWER indicator light and a LED light indicator LAMP flashing?Yes,this is a DLP Tv the lamp live is over,must be replaced it with a new lamp.No,LED light LAMP indicator flashing,than ur tv is a LCD or a Plama tv.Than ur power supply board is dead.Must replaced the power supply board to solved this problems.
May 24, 2010 | Samsung HL-P6163W 61" TV
Sony LCD Projection TV turning OFF.....help!!!
Look carefully at the front lights. Usually when these sets shutdown they have a blink code on either the standby light or the lamp light. Update this with those counts. In the meantime, you may be seeing a problem with heat. If the lamp area gets too hot, the set will shutdown the lamp. Once the area is cool again, the lamp will fire.
Update this and we'll hopefully fix the both of them.
Dan
Apr 09, 2008 | Televison & Video
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
