Question about Kitchen Ranges
Oven door wont close - Kitchen Ranges
  • 76 Answers
Your door don't close,oky have a look at the door seal,if its worn out that could be your problem but, my guess would be the the hinges,theres a spring in the hinges that is worn out and makes the door to hang back a bit,now i cant tell you how to fix it for i don't know the model or name of your oven,but you would see how to do it,its not too hard.
Good luck.
Wouter
Posted on Sep 25, 2008
Oven door wont close.
The thread plate needs to face the screw holes.
Dec 02, 2015 | Belling Country 100DFT Charcoal 1000mm...
Oven light on display says door and now wont heat
The oven will not turn on the heat because it thinks the door is still open. It thinks the door is open because it has a sensor that gets pressed by the door when it closes (look around edges of oven that get covered when door closes) this sensor is wet, dirty or broken so when you close the door the sensor still says its open. Did you clean around the door with a wet cleaning fluid?
Dec 20, 2013 | Whirlpool GBS307PRS Stainless Steel...
Tappan oven door wont close
Is the door lock engaged preventing the door from closing?
Aug 21, 2012 | Ovens
Oven door wont close properly chef gbc5266wng
Wow Must be a very old oven. The closes model number I can get is GBC26CK. But most hinges have no adjustment to them. They just need to be changed out.
http://www.on-timeapplianceplano.com
Jul 23, 2012 | Kitchen Ranges
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
Ge profile range door wont close
was the door removed during delivery? Hinges not being fully seated can cause this. also check to see if the lock is striking the door liner, it should line up with a slot in the inner surface of the door and not touch anything unless the oven is in self-clean
Sep 01, 2009 | GE Kitchen Ranges
Frigidaire plgf390dc stove not working dispay wont go on
The oven door won't close because the oven lock is causeing the door not to close all the way. So is there another way to reset the oven so the oven door can close.
Jun 27, 2009 | Frigidaire PLGF390DC Stainless Steel Gas...
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
My oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Jan 04, 2008 | GE Profile JTP56 Electric Double Oven
Kitchen Ranges Logo
374 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
