Question about LG RZ-37LZ30 37 in. LCD Television
Loud cracking noise sounds like fireworks and wont get a picture
Over the past few weeks everytime we turn on the tv there is loud cracking noises. After turning on and off a few times we would finally get a picture with no sound then after a few more attempts there would be sound with picture. Now there is only the loud cracking noises. We have only had this for two years.
Thank you for any help you can give us.
  • 2,071 Answers
It seems you have loose or cold solder joint connection problem,causing a cracking sound.The solution is to reworks or resolder the solder joint connection in power supply section, audio section and inverter section...
Hope this may help you;
Regards,
VOTIT
Posted on Sep 25, 2008
Loud static noise when I turn the tv on
what tv what model what what ?? all detail is missing past a crystal ball ???? static noise is usually psu or eht sides
Nov 30, 2014 | Televison & Video
Static crackling sounds
Replace the speakers or let it be repaired by some one.their may be rust near the speaker coils.just giv it a try.
Nov 20, 2013 | Yamaha Music
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
My hln5065w started making a loud noise like a fan noise upon startup recently. The color is fine (I've read the color wheel w/loud noise problems). It has been doing this for the past week, previously...
The loud noises came from the tv with a colors wheel design in it have to be replaced every few years,because the spinning of the colors wheel disc are spinning in very high speed in RPM to have it colors for the tv to operate correctly,the humming,loud motors noises and eventually the effect of the tv colors.The colors wheel disc are worn out and spinning hitting it axes motor,the colors wheel must be replaced to solved this problems.
Jul 21, 2011 | Samsung HLN5065W 50" Rear Projection...
Loud noise now tv wont turn on
More than not if it is a loud noise shortly after you turn the set on, the color wheel is bad. The color wheel is not available by itself and requires the complete light engine to be replaced. The part number for the light engine is 75002250. I would suggest having a technician replace this for you if this is the case. Please take a moment to rate my answer. Thanks...
Nov 25, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
My TV is making cracking noise
Its the plastic cassing making the noise. If you press the tv together along the edges you will here a crack. Samsung and others did not use 99 cent padding between the plastic and the metal you need cushion padding. Its like not using a gasket or seal. Its a simple fix but the tv companies say its expansion.
Oct 30, 2008 | RCA 14F512T 14" TV
Buzzing sound
I'm no Expert, but I have worked for a major statelite tv company for the past 7 years,one thing you can check besides the channels, would be the video inputs, see if you have the same issues with different components dvd vcr etc.. if so it would be narrowed to the tv or poss connections to the tele..
Oct 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung DLP loud vibrating noise
The color wheel is the most common problem in DLPs that cause noise. To determine the cause: Turn the set off. If the noise goes away after about five seconds, then, the problem is the color wheel. If the noise goes away one to two minutes after shut off, then, the problem is a fan. You can find an Authorized Servicer in your area that can tell you the price of repair, by clicking on the Samsung link: http://www.samsung.com/Support/ServiceLocations/index.htm
Apr 22, 2007 | Samsung DLP HL-P5663W 56" TV
LG RZ-37LZ30 37 in. LCD Television Logo
398 people viewed this question
Computer Repairing
Computer Repairing
