Question about HP Compaq Presario V2000 Notebook
Everything works but the screen??
My Compaq presario v2000 works wonderfully when I can get the screen to display, 1 out of 10 times ill turn on the power and the screen works just fine...the other 9 times i get no picture and nothing more than a dull gray glow..I know the computer is working because i plug it inot an auxilary monitior and everything is there and functioning. Great little PC when it works!
software issues? should I reload windows? or is it a heat related problem?
an intermittent connection?
flaky hard drive?
bad video card?
Ps I know about the Fn+F4 function..toggling doesnt bring up anything more than the gray glow.
Help please fellas!
Greg
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Please see this reference, as it is a known and identified issue with this model at HP: http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&product=18703&docname=c01087194.
Your issue is a defective machine, and HP should assist you with repairing it or replacing it as appropriate. If you do not one of the specifically identified product numbers, or in a different location, you still have a solid case for getting it corrected. The documentation is there that the product is defective, and HP needs to correct it for you. Good luck - I hope it goes well!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 26, 2008
My compaq presario v2000 has a fuzzy screen and the colors on the backgrounds that are supposed to be white are like and aqua green color and i was just wondering how to fix it. Is there something i can...
First thing you want to try is getting the laptop to display on an external monitor. If it doesn't replicate the same issues then you know it is either the screen or the inverter/backlight.
if it does then it is most likely a motherboard issue and sadly can not be fixed outside of replacing the board.
Dec 10, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
No display at all
gcmichaud:
Take out the RAM and turn on the computer. It should freak out. If not, your motherboard has gone. The good news: your data is safe. If it does beep like crazy, turn the computer off, remove the battery AND ac, reinstall the RAM and hold the power button down continuously for a good, slow count of thirty. Plug in the AC and try again. Let me know if you have any other questions/problems. I'll monitor this thread.
jslo:
It sounds like your power supply died. It's a pretty common problem. Can you get a friend to lend you their power supply? If so, hook it up and see if everything works. My bet is yes.
Jan 28, 2009 | HP Compaq Presario V2000 Notebook
Display Problem Black turns Red
sounds like you have a loose connection ....either into the screen or into the motherboard....the connection between board and screen runs through the hinge brackets and often comes loose after machine has been opened and closed a lot.....need to be comfortable opening up laptops to check the cables as it can be tricky to get to the back of the screen where the end of the ribbon cable is..
Dec 13, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 notebook screen ghosts out and system running slow
for the display you can check by connecting the laptop to the monitor through the vga port
Oct 03, 2008 | HP Compaq Presario V2000 Notebook
Presario v2000
When you first turn the laptop on, wait for the Compaq screen to go then press F8 a few times.
A Windows Start screen will appear
Select "Last Known Good Configuration" and press enter twice.
Apr 13, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 monitor is having horizontal purple lines that flicker.
Try reloading the drivers, delete the device in device manager and reboot. It should then pick up the drivers and reload them, if that does not work I would suspect the screen is on its way out (flickering normally means the screen or its connection is bad)
Jan 26, 2008 | HP Compaq Presario V2000 Notebook
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Presario v2000 notebook problem
Put another monitor and go to the display settings settings advanced and there u can configure display settings if it wont work so just change the monitor
Oct 20, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 Notebook problem
Hi, Take out the battery and plug in only the power adapter and see if it comes on. If it does then leave out the battery for about 15 minutes and then put it back in. Good luck!
May 25, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
