Question about Dell Dimension 5100 (D51L1) PC Desktop
Wont turn on
My computer only beeps at me and will not turn on, do the beeps that I am hearing a code or something? Please help me out
  • 326 Answers
Yes they tell you if there is something wrong
Beep Code Descriptions Document
1 short DRAM refresh failure
2 short Parity circuit failure
3 short Base 64K RAM failure
4 short System timer failure
5 short Process failure
6 short Keyboard controller Gate A20 error
7 short Virtual mode exception error
8 short Display memory Read/Write test failure
9 short ROM BIOS checksum failure
10 short CMOS shutdown Read/Write error
11 short Cache Memory error
1 long, 3 short Conventional/Extended memory failure
1 long, 8 short Display/Retrace test failed
Posted on Sep 25, 2008
Computer won't come on
All computers have beep error codes, if you provide the following details I may be able to help.
1 Make and model of PC
2 error code ( you can count the code for example: 123 could correspond to
Beep - pause- beep beep - pause - beep beep beep
3 does the fan turn
4 does the monitor turn on ok
5 can you hear the hard drive an DVD rom spin a little then go quiet or do they spin and then chuntle on for a little while
Nov 25, 2016 | Computers & Internet
Tip
Computer beeps
If you try to power on your computer and nothing happens but a bunch of beeps there is something you can do. The beeps actually mean something. To make sure you can hear the beeps check in the bios options. If there is an option for a silent boot you won't hear any beeps. If you hear one beep every time your computer starts then you don't have to worry about this.
If you want to check this setting refer to my other tip on how to enter bios and change boot settings.
If you try to boot your computer and nothing shows up on your monitor do these steps first.
1-Check all your cables in the back of the computer.
2-check your power source and power cord to the monitor
3-try another monitor if possible
4-If on a power bar try to turn off the power bar and reset the breaker
If you try to boot your computer and nothing happens and you hear beeps look at this website. The beeps you hear are actually telling you what is wrong. Look at the website by clocking on the link below and click on the computer beep codes link. If you want to scroll down past the link it will show you bios codes to enter the bios in your computer
http://www.michaelstevenstech.com/bios_manufacturer.htm
on Jan 28, 2009 | HP Compaq Presario SR1500NX (PX786AA) PC...
I have a 2005 acer aspire 1500-5674 laptop my problem is i'm getting a black screen on start up but the fan comes on and the lights from my WiFi comes on but still a black screen can someone please...
It sounds like your computer's motherboard has shorted out. When this happens, all the lights on the computer will come on but a fuse has busted within it, possibly one of the capacitors have gave out which can be an expensive or cheap fix depending on how technically inclined you are. If there is no beep codes at all, this is possibly the case.
When you turn on your computer, if you don't hear a series of beeps. It's the motherboard. If you hear beeps and it turns on, it could relate to your Hard Disk, RAM, GPU, or CPU. But there are different beep codes per manufacturer and you can look up the beep codes for your model type. It's pretty expensive to fix if you take it to a shop.
Feb 23, 2013 | Computers & Internet
When rebooted computer beeps 3 times and will not turn on
Is it a long beep or a short beep? Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem before it was able to display any kind of error information on the monitor.
Follow the steps below to determine what system problem the beep code is representing.
Difficulty: AverageTime Required: Anywhere from 10 minutes to a few hours depending on the cause of the beep code
Here's How:
  1. Power on the computer or restart it if it's already on.
  2. Listen very carefully to the beep codes that sound when the computer begins to boot.
    Restart your computer if you need to hear the beeping again. You're not likely to make whatever problem you have worse by restarting a few times.
  3. Write down, in whatever way makes sense to you, how the beeps sound.
    Important: Pay close attention to the number of beeps, if the beeps are long or short and if the beeping repeats or not. There is a big difference between a "beep-beep-beep" beep code and a "beep-beep" beep code.
    This is all important information that will help determine what issue the beep codes are representing.
  4. What steps you take to solve a particular beep code will differ depending on the BIOS manufacturer.
    Choose the correct beep code troubleshooting guide below based on your motherboard'sBIOS manufacturer:
    Tip: Not sure what brand of BIOS is on your motherboard? See this How To Determine Your Motherboard BIOS Manufacturer guide for some helpful advice.
Tips:
  1. Still can't figure out what the beep codes mean? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum.
Jan 03, 2013 | Dell Precision T5500 Computer Workstation ...
My PC wont start up, all it does is beep constantly. I don't have any idea what to do. Please can you help?
Beeping when the computer first starts up indicates a hardware failure. It can be bad memory, bad motherboard or something else is bad.
You can look up the beep codes from your computer manufacturer's website under support or Google It.
If you are not able to replace memory or motherboard on your computer, You will need to have a computer tech look at your computer.
Sep 30, 2010 | Computers & Internet
All of a sudden the pc wont work can start the pc and it's running but just getting a beepeing noise roughly every few seconds help please. Rich
The beeping your hearing is a code, Without knowing how many beeps it's hard to tell what is wrong, But usually indicates a Power Supply issue or even a motherboard issue those are extremes it could be that your hard drive is no longer booting, Or the operating system isnt being found, Usually though that beeping is not a good sign.
I would suggest when your computer starts beeping it is time to seek help from the pc repair shop in your area check craigslist usually some adds on there for inexpensive work
Sep 14, 2010 | Dell Inspiron 530 Desktop Computer
My PS3 wont start games when im signed in on PSN
HI I HAD THAT PROBLEM SO I ASKED THE EXPERT..HE SOLVED MY PROBLEM! BASICALLY THERE A CORRUPTED DATA ON YOUR COMPUTER WHICH NEEDS FIXING.
QUICK STEPS: PLEASE NOTE YOU MAY LOSE YOUR SAVED DATA SO BEST TO BACK UP SYSTEM TO A USB FIRST.
ONCE YOU BACKED UP YOUR SYSTEM FOLLOW THIS STEPS ONLY IF YOUR SURE. THIS WORKED FOR ME, IT WORKS 90% OF THE TIME SO I WAS TOLD BY THE EXPERT. REALLY DEPENDS ON HOW MUCH DATA HAS BEEN CORRUPTED.
QUICK STEP:
  • TURN PS3 TO STANDBY BY PRESSING THE BUTTON THATS ON THE CONSOLE..HOLD THE BUTTON,YOU WILL HEAR FIRST BEEP THEN ANOTHER BEEP 5SECONDS LATER, THEN THE THIRD BEEP. HOLD BUTTON DOWN UNTIL THE LIGHT TURNS RED THEN MOVE FINGER.
  • NOW SWITCH ON PS3 HOLDING POWER BUTTON ON THE CONSOLE..HOLD THE BUTTON DOWN YOU WILL HEAR FIRST BEEP THEN ANOTHER BEEP 5 SECS LATER, THEN TWO BEEPS TOGETHER.LET GO OF BUTTON WHEN YOU HEAR TWO BEEPS.
  • IT SHOULD SAY SOMETHING ABOUT CORRUPT DATA. AGREE TO IT. SOON YOU SHOULD HAVE A 6 OPTION MENU COME UP.
  • PRESS NUMBER 3...RESTORE SYSTEM FILES
  • IT SHOULD THEN RESTART COMPUTER.
  • NOW TRY PLAYING YOUR GAME ONLINE.
  • ITS MEANT TO WORK AS IT DID FOR ME.
IF IT DOESNT WORK THAT MEANS THERES ANOTHER PROBLEM. I WOULD ADVICE YOU TO ASK THE EXPERT. THEY TELL YOU STEP BY STEP, THEY FIXED MINE IN HALF HOUR. ITS WORTH EVERY PENNY.IF THEY SOLVE YOUR PROBLEM THAT IS! HOPE THIS HELPED YOU GUYS...GOODLUCK!
Jul 30, 2010 | Sony Playstation 3 (PS3) Console
Tower pushing out air and beeping and can't turn on PC
the beeping is post codes. they are telling you something is wrong. the code is a code for what is wrong like 3 beeps 4 beeps 1 Beep then repeatsthat code is 341. first thing i would do is pull out you ram and reseat it. that is the most common problem.
Jun 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Starting up Problems
I found it 2 min. ago. Ok here: while your ps3 is on hold the power button on the ps3 for you will hear one beep, keep holding it then when you hear the second beep take your finger off. Your ps3 should turn off. Now push the power button while holding your finger on it again, you will hear two single beeps, then a double beep, let your finger ago and a screen should appear with six options. Chose something like reset(or restore) file data or something like that and click yes, this wont do anything to your game/music/movie/etc. files but now your ps3 shall work.
Feb 01, 2009 | Sony Playstation 3 (PS3) Console
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
Dell Dimension 5100 (D51L1) PC Desktop Logo
417 people viewed this question
Alun Cox
