Question about HTC G1
G phone problem?
I read in one of the blogs that the G Phone have hardware problem and that the the plastics weren't high quality and the trackball didn't work all the time.
Does anyone know if its true?
  • futurevip May 08, 2009
    Trackball only moves left, right and up, no down movement. It's off and on, but it can be really annoying if you are trying to scroll fast. I still have not fixed this problem. Any hints on how to repair it?
When i try to upload my music it doesn't work. I drag and try to paste and i get a message saying its unable to do so. the only files that come up are amazonmp3 and dcim....no music file or anything....
What am I supposed to do and how is it done?
Posted on Nov 11, 2008
    Novelist:
  • 111 Answers
Whoever was posting that blog must have either being Talkin a load of garbage or they had a one in a million bad quality HTC Phone..
the G1 is Really High quality, yeah the phone is all plastic, but so what !? it looks amazing, it feels really solid and robust in the hand and the back of the phone has a slight tactile texture which makes it firm in your hand. the plastics are really high quality throughout and there is nothing wrong with the hardware at all !
Posted on Oct 27, 2008
How to unlock motorola v3xx at&t 3g
Hi, You can unlock a Motorola V3XX safer and easier using unlock code. You can get the unlock code for a Motorola V3XX from www.simpleunlocking.com/motorola-v3xx/rs16wp9/ at low cost.
UNLOCKING STEPS FOR MOTOROLA V3XX
1 - Switch ON your Motorola V3XX with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
Oct 10, 2012 | Motorola Mobility Razr V3xx Cingular At&t...
Tip
How to fix a faulty Blackberry rollerball/trackball
There are a few relatively simple solutions to fixing a faulty Blackberry rollerball/trackball.
Compressed Air
Spraying some compressed air on the ball and round the sides of the ball can sometimes loosen the compacted dirt & dust on the rolling mechanism.
You can pick up compressed air from your local hardware store.
WD40
Spray a tiny amount of WD40 on a cotton bud and rub it onto the rollerball. This can free up the mechanism and lubricate it.
Removing and Cleaning the Rollerball/Trackball
  1. Using a small flathead screw driver gently prise the silver ring around the rollerball from the top (be extremely careful as the catches are made of plastic and can break easily)
  2. The rollerball module should come out with easy
  3. Using a clean paint brush, gently brush the inside of the Blackberry where the module came from
  4. Using a toothbrush clean the rollerball module gently around the rollers on the underside and also clean the actual rollerball
  5. When replacing the rollerball module it will only fit one way so don't worry about putting it in upside down
  6. There are three plastic catches on the silver ring, there should be one at the bottom & two at the top. Line them up on the phone and press it back in place gently.
Replacing the rollerball/trackball
Sometimes the mechanism or the rollerball can be come damaged and cleaning will not solve the problem. In this case you can replace the rollerball by following the instructions above about cleaning and purchase a replacement rollerball from eBay or one of the other countless online stores that see Blackberry parts.
I would always recommend that you buy genuine Blackberry replacement parts as these are usually of a higher quality than copies.
on Dec 18, 2009 | Cell Phones
The screen is black and neither the keypad, trackball or buttons work
Welcome to Fixya
Sounds like the keypad and trackball is failing. Try to reinstall the BB software of the phone. Its either the 4.6 of the 5.0. If same thing happened after reinstallation then its gonna be a hardware problem.
Thank you for using Fixya!
Apr 24, 2011 | Cell Phones
I have a blackberry phone and the cursor on the phone don't go down, only sideways and up
The problem you describe is a common occurrence with all BlackBerry phones with a trackball. The cause of this is a build-up of dirt, dust, lint and debris that gets trapped under the trackball. Over time, the build-up fuses together with the natural oils on our fingers as we spin the trackball. This leads to small chunks of dirt trapped that get big enough to prevent the trackball from spinning in a given direction - and sometimes even from being able to press down on it to make a selection.
To fix this, you will need the following items:
A. BlackBerry (with Trackball) B. Small, flathead screwdriver (Jeweler's driver) C. Toothpick (1) D. Lint-free cleaning cloth (or toilet paper/napkin) E. Q-tip (2)
1. Power off the BB and remove the battery cover and battery 2. With the phone facing you, insert the small, flathead screwdriver between the outside of the chrome track ring and the edge of the plastic phone face. 3. Slowly apply pressure downward, as if you were trying to open a can of paint. 4. There are 3 tiny clips that hold the track ring in place. Slowly wedge around until all three have been loosened. (Be careful as these are extremely fragile pieces and if they break, there's no repairing it, only replacement). 5. Once you remove the track ring, you can easily remove the trackball. 6. Look inside the the hole where the trackball was and if you spot any "gunk" or build-up, use the toothpick to flush it out. (Be careful not to damage the expose logic board) 7. Once any build-up has been removed, take the trackball and using a Q-tip, gently roll the ball around while also pushing the ball in, so as to free any trapped debris. 8. After a few swabs and after any visible gunk has been removed, insert the trackball and then the chrome ring, carefully! 9. Roll the trackball around and check for any blockage. 10. If there is blockage, disassemble the trackball and track ring again and repeat steps 6-8 until clean. 11. Once clean & reassembled, insert the battery and battery cover and power the BB on. 12. Check/re-check scrolling and selecting with the trackball, verifying that it works correctly.
Aug 11, 2010 | RIM BlackBerry Pearl 8100
How to clean up trackball for curve, cause it won't scroll down....only to the left and right...thx
everyone has the same problem with blackberry trackball. i wonder why the rim installed such a hardware in their phone. it makes a lot of trouble.
to fix it simply use a straw, no need ro replace or disassemble the blackberry, read more from the source http://www.unique-stuff.co.cc/fixing_sticky_blackberry_trackball.html
Dec 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
Trackball won't enter
what kind of phone is it?
Aug 20, 2009 | Cell Phones
My blackberry world edition's trackball suddenly started selecting things as if I pressed the trackball even though I haven't. If I open email it clicks the links in it as I scroll past and reply pops up...
You might have one of three things wrong with your blackberry 1. something is stuck down there like a peice of plastic causing the button to seem like its being pressed all the time or 2. there could be water damage in there thats if you bring your phone into the bathroom with you while taking showers humidity is like cancer to phones it might not show up right away but it can happen 3. someone might of pushed the trackball so hard that it dented the button in this case i would take it in to get repaired. If it is one of the other two it should be an easy fix you can check for either one of these problems underneath the trackball by removing the ring that is around the trackball you can do this by carefully prying around it off then you should be able to drop the trackball itself right out of the phone aswell as any thing stuck in there or if there is water damage or any water down there I suggest you turn the phone off as soon as possible to prevent any further damage then I would just leave the phone in a nice dry place to get rid of the water then the trackball should work again same thing goes for removing anything that might be stuck down there after that is all done with you should be able to reassemble it remember the ring around the trackball only goes in one way so do force it or you risk breaking it.
Cheers,
Kyle
Jul 05, 2009 | RIM BlackBerry ® 8830 Cellular Phone
Trackball Is Brocken!
Good evening!
Trackballs are VERY easy to replace! You can take it to your cell phone provider but there is a good chance they will claim the phone is broken.
I would recommend searching on Amazon.com, Ebay, or just googling Blackberry Trackball replacement. They are inexpensive, range from $2 to $10 depending where you look and the quality of the trackball.
I personally have replaced my Blackberry's trackball with a new one off of Amazon. It is very easy to replace. You just need to be careful with handling the trackball due to they are very fragile.
Here is a bunch of replacements you can look into on Amazon:
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=blackberry+trackball&x=0&y=0
Youtube even has a few videos on replacing the trackball.
Glad to help you out and good luck with your Blackberry!
Jan 16, 2009 | RIM BlackBerry 8700g Cellular Phone
Install my trackball and rim
ladyhaws - take the phone to a mobile service center and have the trackball service.
csu - take the phone to a mobile service center and have the trackball replaced back in..
Oct 11, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
HTC G1 Logo
1,112 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
