Question about 3M MP 8749 Multimedia Projector
Loud Bang and Projector no londger works
I turned on the power on to theProjector and there was a very loud bang and now the projector is no longer accepting power. no standby light. I checked the plug that fine, so i think something has blown in the unit. The bulb looks ok. I didn't get as far as trying to power up the bulb before it blew.
I'm wondering whether it would be cheaper to get it repaired or just to buy a new unit
  • 23 Answers
If the internal fuse has blown, if you connect the power lead loosely and move it about, you should not be able to hear any crackling sound of electricity. If you do then it is more likely something else other that the internal fuse. Generally, a loud bang is either the fuse or lamp.
Posted on Apr 20, 2010
    Problem Solver:
  • 3 Answers
Hi:
I works on this product for 3M here in Puerto Rico and i see this problem often.Probably you have the fuse blown but you have to find why the fuse blew because if you replace the fuse and it hapen again then you have a power supply problem.Just replace the fuse and see what hapen.You can probably get the whole power supply assy.calling 3M or on ebay shiper.
Good luck and fill free to contact me for aditional help.
jorge
Posted on May 24, 2009
  • viktormax1
    viktormax1 Feb 26, 2013
    Hello jorge,I have the same problem. Where is the fuse located?is it easy to replace?
  • 563 Answers
Hi there
Theloud bang you heard was probably just a fuse that blew and the fuse will probably cost you in the order of 50 cents.
This can be found at any TV repair shop or hardware shop and is located on the Main Powersupply Board ( the one that takes in the AC socket )
Before opening up the whole Projector to replace the fuse , just double check and take out the lamp and check for any damage. If you heard a bang the lamp would be shattered.
Posted on Sep 26, 2008
Heard loud bang and now no power
About 745,000 results (1.02 seconds) Search Results
    Loud bang and loss of power - Ford Truck Enthusiasts Forums
    www.ford-trucks.com > ... > Diesel > 6.0L Power Stroke Diesel
    Dec 11, 2004 - Loud bang and loss of power 6.0L Power Stroke Diesel. ... No matter how much throttle you give it, it won't accelerate. If you get to 2200-2300 ... 4r100 loud bang then nothing
    Jun 16, 2012
    loud pop no turbo boost
    Aug 13, 2011
    LOUD pop, no power, no boost!! Now what?
    Nov 9, 2008
    Loud bang when I tried to enguage 4 wheel drive. Now 4x4 wont ...
    Feb 25, 2007
    More results from www.ford-trucks.com
    loud bang while in 4wheel drive now 4wheel no ... - CarGurus
    www.cargurus.com > Questions > Ford > F-250 Super Duty
    CarGurusDec 1, 2014 - 10 mph a very loud snap bang from under the cab (I think) now... ...Could probably hear it from 50 to 75 ... truck - no cut wires - i have no power to my 4 wheel drive button on the inside of my truck ? any ... Used Cars For Sale.
Jan 29, 2016 | Cars & Trucks
92 Previa, loud bang and van died any idea what happend? What could the bang be?
loud bang could of been your battery. have you replaced the battery? any problems since?
Apr 21, 2014 | 1992 Toyota Previa
Bang
was there smoke, or the smell of smoke/burning. Its more than likely a compasitor, and unless you know how to electrical trouble shoot, and sodlier then you will need a new one. We call if magic smoke in the electrical industry, and its never good.
good luck
Apr 30, 2013 | Epson PowerLite 77c Projector
Loud bang switching to 4x4 uphill
Could be one of your hubs wasn't fully locked or maybe your transfer case wasn't fully ingaged
Jan 03, 2013 | 2000 Ford F350 Super Duty Super Cab
Starter suddenly stopped working. Loud bang when
It's most likely a timing problem, you may try too adjust it yourself; Loosen set screw on distributor and get a timing light. there also a chance it jumped a timing gear when you heard the loud bang..
Jul 11, 2010 | 1994 Chevrolet Corvette
OUr Tv will not turn on. It also makes a loud bang when tring to turn it on.
DO NOT TURN ON THIS SET.
Take it to a qualified television technician or have a house call made to repair the problem.
The only things which can cause a loud bang from electronics are things you DO NOT want to mess with.
It is most likely a problem with the power supply.
Oct 06, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Fuse made a loud bang. Put in new 13a fuse and
Probably the wires inside melted together and now as shor circuit occurs it causes the fuse to blow. remove the bottom of the kettle and check the wiring. There's no rocket science, so you'll identify the problem after visual inspection.
Best of luck
Aug 07, 2009 | Tefal Elegance Brushed Chrome Cordless...
Loud clicking, banging noise
We recently had the same problem. After cleaning both the furnace filter and the humidifier water panel, the clicking noise (electric air filter) and the loud bang went away.
Nov 30, 2008 | Aprilaire 550 Humidifier
Loud bang, unit stopped working
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
Jun 24, 2007 | Sony FWD-50PX2 50 in. Plasma Television
3M MP 8749 Multimedia Projector Logo
268 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
