Question about Gigabyte Computers & Internet
Memory card replacements in two PC-s.
Want to upgrade memory cards in two computers. They both have 'gigabite' motherboards.
Computer 1 : P4 Titan series Motherboard. GA-8S648FX-775(-C). SIS 648 FX chipset.
Question : What one gig, or two 500 megabit memoricard(s) would be compatible with the above motherboard???
Computer 2 : RZ series motherboard. 8S661FXMP-RZ. SIS 661FX chipset.
Question : Same as for the P4 ***án series motherboard, above.
My email address is : agrobszi.1@bigpond.com
Please reply.
Regards, Robert J. Szigeti.
P.S : The above motherboard numbers were placed in my computers and they are genuine, GIGABITE products. Please REPLY!!! It is impossible, to get your attention for your own product. I am in Ausztralia and need help!!!
    Sergeant:
  • 359 Answers
Computer 1 = DDR400 Memory
Computer 2 = DDR400 Memory
Dude, next time you should try http://www.google.com
Posted on Sep 25, 2008
  • Daniel Jenkins
    Daniel Jenkins Sep 26, 2008
    please rate my solution.........
Can I switch out a Trident CyberALADDIN-P4 video card for an ATI Radeon 9600XT or equivilant?
The video card on a laptop is built-in on the motherboard and cannot be swapped to another video card.
You maybe able to increase the video RAM in the BIOS video settings BUT it will reduce your main memory by the corresponding amount because the video uses shared RAM.
Mar 22, 2012 | Toshiba Satellite A25-S207 Notebook
Wont to upgrade graphic card my p.c has 2gig max ram in it wonts should i upgrade to to preform its best cheers mike
Depends on what kind of hardware you have
-Memory- 2 gb ram is "ok" if you use windows XP but if you have Vista or Windows 7 you should have a minimum of 4gb ram.
-Processor- if you have a Dual core processor you are ok, if you have a p4 or p3 you dont want to waste money on a new graphics card because it will not help you get better games, your processor and memory will slow you down instead.
So my advice is, if you have a OK computer, go ahead with buying a new graphics card if you computer is old and slow, DONT buy a new card! put your money on +2gb ram instead (cheap,and gives you more benefits) or maybe buy an "upgrade package" with new motherboard-memory-processor.
May 05, 2011 | Computers & Internet
Beep and blue flashing light monitor states going to sleep
in that case you need to open the tower or CPU and reseat RAM and graphic card if you have 1
and then try to start the computer
it should work
and if you still get beeps.
and can try to plug memory card 1 by 1
if you have more than 1 memory card
if the computer starts with 1 memory card
then it could be the issue with the memory card
if not then the slot on the motherboard is gone bad
and the motherboard needs to be replaced or repaired
Mar 28, 2011 | Medion MD-1704 PC Desktop
I have a p4 computer with u8668-d mother moard, it has no dislay.what am i supposed to do? cpu fans are running,,i cheched the RAM and its functining well.how i solve it?
First try re-seating the memory boards. Try removing all memory boards except for dimm1 to test for bad memory chip, then replace dimm1 with other one(s) just to be sure. If problem persists, try reseating the video card and if still no go, remove all other add-in cards (except video card) and try to boot. If ok, add the cards back one at a time to determine the problem device. I had similar problem and cleared up with a new video card and another time it was a poorly seated modem card. Sometimes you also need to reset the BIOS by unplugging the power, and placing the jumper cap for your BIOS Reset or CMOS Clear (usually marked on motherboard) from 1-2 pins to 2-3 for a few seconds then return to pins 1-2 before pc restart. (pin nos. could be reversed depending on the model).
Sep 11, 2009 | Biostar U8668D (802700113338) Motherboard
Replacing the motherboard and/or cpu on an Emachine T2958
Your motherboard can handle a P4 2.8Ghz chip with 1MB cache or you could go to the P4 3.06Ghz chip with 512KB cache. And either one would give you a bit of a performance improvement. I think the bigger question would be: is there any place locally where you could get a screamin' deal on a motherboard/CPU package that would still support the memory your currently have?
A motherboard replacement would not require you go purchase a new retail MS OS. It would require re-activation of your current product though which could entail a toll-free phone call to Microsoft and your existing product key.
Apr 10, 2009 | Computers & Internet
Cricket07 and NFS underground not running on my pc
how much memory does your video card have I suggest you add more ram and a bigger memory video card it sound like your computer is using your hard drive as temporary memory
Jul 21, 2008 | Mercury P4VM800M7 Motherboard
Dell Dimension 3000 PC Desktop Burned Out w/Memory Upgrade
Is the video card built into the motherboard? If not you can try replacing just the video card to see if that works. Otherwise I am afraid you may have to replace the motherboard.
Feb 02, 2008 | Dell Dimension 3000 PC Desktop
Upgrading
To upgrade from pentium 3 to P4 you have to change alot of the hardware.
You need a NEW P4 Socket mPGA 475 Motherboard.
New DDR RAM
New 478 PIN Processor.
You can use the old CD rom and Hard drive and any other PCI card but You Need the Mentioned Hardware to Upgarde.
Jan 08, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Titan p4 667 series gigabyte motherboard
According to this list on GigaBytes homepage
http://www.giga-byte.dk/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1406
You'll be fine for quite a while, until the 478-socket processors are available in stores.
Your motherboard supports much faster CPU's than your current Celeron, so if money is short upgrade our processor.
But if you want to secure your motherboard for future upgrades, then I suggest you get one that support the newer dual-core processors, and PCI-Express instead of AGP.
Allthough you can still get pretty good GFX-Cards on the AGP-standard the PCI-E standard is the future.
I hope this answered your question :-)
Oct 17, 2007 | Computers & Internet
Computers & Internet Logo
155 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
