Whenever I try to print out a word document only half of it ever comes out ( the left hand side ) but the right hand side is completely blank. Is this likely to indicate a printer problem or the way the document is set up ? - I think te ink is starting to run fairly low so don't know if this is perhaps the cause of it.
    Problem Solver:
  • 5 Answers
Try to change text orientation form portrait to landscape.If the black is on the same side of the text problem is on the document, if black is on the same side of the paper problem is on the printer.
Posted on Sep 25, 2008
My rimage perfect image only prints half of a cd
Bad print head,
John Norman
Max Optical llc.
www.maxoptical.com
Jan 27, 2012 | Rimage Perfect Image Prism Thermal Printer
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
Canon PC-D320 prints only left half o document with closed cover
I had the same problem but it was caused by the scanner that was not running flash under the copier glass,if I remember correctly there are spacers on the scanner that keep the scanner to run exactly the same distance from the glass of both sides of the scanner.
On the other machine,I found a faulty scanner cable that cause a similar problem.
Jan 30, 2009 | Canon PC-D320 Copier
Fax machine does not print on the right side of paper
Probably the thermal head is bad. It's a spring loaded bar inside of the fax machine. You might be able to shim it closer to the paper on the bad side.
Oct 20, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Failed to print
Uninstall the printer driver and restart the computer! Disconnect the printer from the computer and then reinstall the printer driver.
Dec 05, 2007 | HP OfficeJet 4255 All-In-One InkJet...
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
170 people viewed this question
jasbo
jasbo
