Question about GE J1455 Digital Camera
How cani unlock my camera? i cant delete my pictures?
  • GE Master
  • 17,970 Answers
Erasing a memory card: when erasing a memory card, individual photos are deleted from their directories on the card. You can erase one or more user selected images at a time, or erase all images at one time. However, any images that you've selected to be "protected" through another menu option will not be removed during the erasure process.
Formatting a memory card: format a memory card sample menuFormatting, on the other hand, deletes all images from a memory card, even the ones that may have been protected. It recreates the file system including new directories and folders where images are saved on the card.
Unlike erasing, formatting improves the overall performance of a card.
Low level formatting: some digital cameras offer a low level format in addition to the standard format option. With a low level format, all data on the card is deleted. New directories and folders are also recreated during this process.
A low-level format of a high speed memory card helps ensure smooth continuous shooting at a constant interval. For optimal video performance, it's also recommended that a low level format be done sometime prior to recording.
In camera, not computer: though opinions vary, many recommend formatting a memory card in a digital camera, not via a computer. If you plan to use a memory card that was previously used in another camera, format the card in the new camera before taking any shots.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Posted on Nov 02, 2011
  • ZJ Limited
    ZJ Limited Nov 02, 2011
    Keep in mind that, if you need unlock a SD Memory Card remove from the camera... you will find a slide switch on the side of the card that needs to be slid to unlock the card.
SOURCE:
I cannot delete a picture as the screen says file protected. How do I remove?
if you cant delete any pictures then your sd card is locked which means you take it out and slide the little movable plastic,
if its one pic then you must unlock it in the properties menu
Jul 28, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
The card, or memory chip in camera is locked, and i dont know how to unlock it, so now i cant take pictures, or upload my pictures, or even delete photos,i just need to know how to unlock my camera.
This used to happen when the write protect lock on in the memory card. Refer the manual to see how to remove the memory card.
After removing the memory card, unlock the write protect tab as shown in the fig. d7656e6.jpg
Apr 20, 2010 | HP Photosmart M547 Digital Camera
Can't delete old pictures
It depends on the brand or model of camera you are using, but if you cant get how to delete a picture from your camera, simply get a card reader, then remove the memory card of the camera and insert it into the card reader, connect the card reader with your computer, so from your computer you will be able to delete old picture. But I still know that most digital cameras should be able to delete old pictures, simply read your camera manual to see how to delete or you tell me the model and brand of the camera that you are using.
Sep 22, 2009 | Cameras
There is a key symbol on some of the pictures
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Download site for your User Manual. On page 45 it tells you how to lock and unlock images on your camera.
OpenSource13
Apr 05, 2009 | Vivitar ViviCam 4100 Digital Camera
How can i delete pictures on my digital camera
Push the delete button or the little picture of a trash can. You must make sure the picture is unlocked. Your memory card has a little switch. Make sure it is set to unlocked. (not on locked)
Mar 19, 2009 | Olympus D-400 Zoom Digital Camera
Cant unlock a picture
If you want them to be permanently deleted you can format the memory card and this will clear the card of all data. If you just want these certain images deleted then you need to be in Playback mode - press the Menu button - go to Playback menu and press Ok - then choose the key option and turn it from ON to OFF. This will remove the lock and allow you to erase the selected image.
Dec 17, 2008 | Olympus Stylus 710 Digital Camera
Retreiving accidentally deleted pictures
Once you delete anything off scan disk or flash drive they are gone forever ...
Sorry about your loss of photos
Jul 29, 2008 | SanDisk (SDWSDB-256-A10M) 802.11b Wireless...
Card locked
move slider switch on side of memory card to unlock card
May 16, 2008 | Samsung Digimax D53 Digital Camera
Cant remove picture on digital camera
As per the last persons solution the key icon does indicate you have locked the photo. First select the photo you want to delete, press menu, select playback menu, the key icon appears, press the weird shaped arrow button to the right of the OK; phot unlocks and allows to delete!!
Feb 29, 2008 | Olympus FE-220 Digital Camera
GE J1455 Digital Camera Logo
62 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
