Question about Panasonic Viera TH-42PX80U Plasma TV
My th-42px80u appears to be in zoom format although it is in full format. i have tried to change it but even on full format, it is a zoomed picture. how do i zoom out so i can see the whole picture?
You probably have a tv decoder cable or satellite witch also has a aspect converter
Posted on Nov 09, 2011
SOURCE:
Screen no longer contains all picture that should be viewable.
Check in the menu of the set to see if you inadvertently have set the screen size to a "zoom" mode. There are some sets that have fill & stretch features to make the 4:3 picture full screen and these can cause cutoff of the normal wide screen format when on those channels.
Sep 19, 2015 | Panasonic Viera TH-42PX80U Plasma TV
There is no zoom or aspect ratio on my Panasonic Vierra remote and the picture is too large for the screen. How can I fix this problem
Try exploring the picture set up menus on the device that is supplying the picture, it may be a cable box or DVD player or other. Change it to 16:9 ratio on that device. Does the problem exist for all types of devices supplying pictures to your TV or just one?
Dec 15, 2013 | Panasonic Viera TH-42PX80U Plasma TV
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
How to format my PHILIPS flat screen. I want the picture to be full screen
On the picture menu, you can select between 16:9, 4:3, zoom 1, zoom 2, etc. Depending on the station you are watching and whether or not it is an HD station, selecting zoom 1 or zoom 2 on your TV remote might give you full screen. Otherwise, on some DISH remotes there is a format or zoom button that will also change the size of the picture.
Feb 27, 2011 | Philips Televison & Video
Hi our panasonic viera has a very large picture that does not fit into the frame of the TV. Normal option under picture isn't available and zoom isn't working either is aspect
hi hust a tip hope it would work, try to adjust the aspect ratio, if not check if ther is a zoom button on the remote that can actually adjust the size of the picture but normally adjusting the aspect ratio will solve the problem. hope this would work, goodluck!!!
Jun 03, 2010 | Panasonic Viera TH-42PX80U Plasma TV
I want to know the perfect color settings for the th-42px80u
The Settings are :-
-Picture menu Picture mode: Custom
Picture: +80
Brightness: +60
Color: +44
Tint: -8
Sharpness: 0
Color temp: Warm
Color management: On
x.v.Color: Off
Zoom adjust: [grayed out]
-Advanced picture submenu
Video NR: On
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: [grayed out]
Black level: Light
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 10, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Cant see full picture w/ Vizio 32in HDTV
You would look for a format button on your remote.
Dish Network: bottom left the asterisk "*" button
DirecTV: top left, second from the top labelled "format"
Cable remote: look for format, zoom, or aspect ratio
Pressing this button should scroll you through the options.
Apr 16, 2008 | Vizio L32 32 in. LCD HDTV
Can't playback pictures
Try formatting the memory card in your camera. Search the camera's menus to find the option that lets you do a "Full" or "Low Level" format, and NOT a "quick" format.
Feb 12, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Panasonic Viera TH-42PX80U Plasma TV Logo
514 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
