Question about HP LaserJet 3030 All-In-One Printer
HP Laserjet 3030 fuser roler broken
Yellow / black plastic came out where paper comes out. Now paper gets jammed. What do I need to do
  • 47 Answers
Buy a new fuser, the teflon on the fuser roller is missing though it came out
Posted on Nov 05, 2008
Hp laserjet 3030 paper jam
I would start here by cleaning the feed rollers but there could be several causes to this. It could be the fuser film is slipping and not getting the paper out in time thus throwing a false paper jam message. It could be the fuser isn't turning at all and not allowing the paper to enter. Normally if the paper is making it out of the tray then it isn't the feed roller but that is always the cheapest place to start. You can clean the roller(s) with an alcohol wipe or rag with alcohol on it.
Does the paper make it past the toner cartridge? I have seen toner cartridges lock up and cause this type of problem as well. If the paper isn't making it past the toner I would try replacing the cartridge (even if its with an old one just to test the paper path).
Feb 19, 2015 | HP LaserJet 3030 All-In-One Printer
Hp 3030 laserjet paper creasing when printing
if the print is also smudged the fuser needs replacing
Jan 12, 2010 | HP LaserJet 3030 All-In-One Printer
Hp LaserJet 3030
Make sure that the paper size is set to letter, not legal. Check this on the printer and the computer printer software.
Aug 21, 2009 | HP LaserJet 3030 All-In-One Printer
Seems to jam in fuser, fuser has been replaced
if it always jams at the same place (fuser area) try another fuser or check the BLACK PLASTIC ASSY. THAT is mounted in the left door and takes the paper right after it comes out of the fuser ;part is called (PAPER DIVERTER) And sometimes one of the FLAPS That routes the paper is broken,hence causing paper jam.
Jul 30, 2009 | HP LaserJet 9050 Printer
HP laserjet 5500dn paper jam at fuser
I was able to fix my problem. On the left side of the fuser assembly there are two small plastic tabs or flags that move up & down. One is attached to the plastic rod/flap that you can see from the top of the fuser and moves when the paper comes out of the "chute". The other tab, which is below the first tab and moves when the paper has passed some point in the fuser, was broken off. I glued the tab back on and now the paper is ejected from the printer like it is suppose to.
I'm thinking that the broken tab was part of a page sensor flag that would tell the printer to stop rolling the fuser assembly when the paper was ejected. Without the flag, the sensor would disengage the fuser prematurely and stop ejecting the paper while the paper was still in the fuser.
Charlotte
Apr 17, 2009 | HP LaserJet 5500DN Printer
PRINTER JAM ON STARTUP
If you replaced the fuser roller, check for a little sensor flag that is right there as the paper exits. You may have misaligned it. It's easy to move out of place. Also make sure that you didn't disconnect any of those little plastic connectors.
Nov 18, 2008 | HP LaserJet 3030 All-In-One Printer
Paper feed
in the fuser assembly, pressure roller might be gone over it has to be replced and greasing has to be done
Apr 21, 2008 | HP LaserJet 3030 All-In-One Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 3030 All-In-One Printer Logo
268 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
