Question about Canon PowerShot S3 IS Digital Camera
The LCD went black, all the icons are showed, but no pictures. Any taken pictures are also black! Already reset the camera in factory settings, didn't help... anyone???
The LCD went black, have tried lot's of sollutions found on the net, they didn't help me!  Icons and so on are displayed properly, but no picture... We have set the camera back to factory settings, this also didn't help.
Can anyone help us???
Tnkx
  • maxinemarker Dec 13, 2008
    I have a Canon S3Is The light is red when I turn it on I can see old photos light goes green ,when I try to take new photos the screen is black and the light goes red again
  • Anonymous Dec 29, 2008
    Argh same problem with my S3IS . . .
Unfortunately, I have the exact same problem and just got off the phone with Canon (1-800-828-4040 for tech support). According to their reps the S3IS is not on the list for replacement and I was quoted a min. fix price of $150.00.
Posted on Sep 27, 2008
    Problem Solver:
  • 11 Answers
To ivowitteman
Bad news & Good News
The BAD news is that it sounds as if your CCD has gone wrong which is the part of the camera that captures the image. The CCD is made by Sony & there is alot of dodgey ones out there that Sony have said sorry about. (type "bad CCD" on a search engine & you should be able to get more info)
You say that the icons appear so the rear LCD must be working. If the playback of pictures from a card also works then it is almost certainly the CCD at fault.
The GOOD News is that your model is one of the ones that is listed as eligible for a free replacement of the CCD. You will need to contact Canon & they will advice of what to do. I have sent several cameras of different makes back to the agents for repair & all have been repaired for free. The fault you have first occurred a few years back now so there will probably be a point where the agents will say enough is enough & stop the free repairs.
Hopefully you will be eligible for the free replacement.
Hope this helps
FlashyBits
Posted on Sep 26, 2008
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
Black lcd screen on Ixus 70 shows icons but will not take picture
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My olympus fe-170 lcd screen won't show ANY pictures.
it would appear that the lcd screen has malfunctioned and would need repair.... you can try power cycle by taking batteries out and press and hold power button down for 10 secs, draining all power out of camera, then put the batteries back in and try again
Dec 16, 2008 | Olympus FE-170 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
LCD screen black, no viewed image displayed.
Hold down the display button for a few seconds...
It worked on my Caplio R7 which was doing this all weekend...
hope this helps
Jul 31, 2008 | Ricoh Caplio R30 Digital Camera
Why does the LCD act crazy?
select reset all function in menu and press ok. Your camera will set on default factory setting.
Mar 16, 2008 | Canon PowerShot A570 IS Digital Camera
LCD Black
Contact Damage support - there appears to be a problem with this model
http://www.google.co.uk/url?sa=t&ct=res&cd=1&url=http%3A%2F%2Fca.konicaminolta.com%2F&ei=bzOwSMj2CYreQd-i-Gg&usg=AFQjCNEEQPR1zDRvdYe3DCF0EhXowwYetw&sig2=AAutefCXmdjtFGCFF7XjRg
Oct 26, 2007 | Konica Minolta DiMAGE E500 Digital Camera
Reset to factory original
If you go into the "set-up" menu you should find an option which allows you to reset all the settings back to factory original.
Sep 28, 2007 | Fuji FinePix V10 Digital Camera
LCD is black
you can see images clearly? but no Menu items show is that what you mean? This would indicate a firmware malfunction. If you see nothing at all on the screen but only 'ghost' images then the back light has blown. Try first of all with the camera on tapping gently at the base of the casing in the region of the screen- this is where the connectors to the main board are. Contact The Minolta support team. If you are getting nowhere - I suggest the next camera - repairs are not usually an economic option if at all.
Jun 27, 2007 | Konica Minolta DiMAGE E500 Digital Camera
CAMERA WON'T TAKE ANY PICTURES
I have the same problem since yesterday! When I switched on the camera it shows only black screen with all the settings on it. I can change the settings and I can take a picture,but it will be only a absolutely black picture! :(
Jun 12, 2006 | Nikon Coolpix 5700 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
164 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
