Error f2 in copier ar 5127
I replace the toner in copier ar 5127 and i have error F2 what can i do
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is there an 02 at the end of that? If so it could the toner sensor is dirty and needs to be cleaned.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
F2:
00:TONER SENSOR
02:TONER SUPPLY PROBLEM
04:WRONG COUNTRY,WRONG CARTRIDGE,DRUM
05:DRUM PROBLEM,WRONG CARTRIDGE
39:PROCESS UNIT THERMISTOR PROBLEMS
58:PROCESS HUMIDITY SENSOR PROBLEM
Posted on Sep 26, 2008
Sharp AR-5127 error code F2-04
CRUM data read trouble
Replace the toner cartridge.
Replace MCU PWB.
Replace MCU PWB EEPROM
Check and fix connection between
CRUM (toner cartridge) and MCU
PWB.
May 18, 2014 | Sharp AR-5316 Advanced Digital Imager...
F2-64 on sharp AR-5318
sharp ar 5618 zerox machine in f2 64 error solution
Aug 04, 2012 | Office Equipment & Supplies
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Error f2 in sharp copier AR5316E
F2 sub code 00 - Toner Sensor problem, ID pattern reading error. You may have to replace the drum unit or have a tech clean the toner sensor
Mar 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
484 people viewed this question
k24674
jasbo
jasbo
