Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch error message
F17
  • 725 Answers
F17 is a water pressure error not enough water pressure.
Posted on Sep 25, 2008
2 Suggested Answers
SOURCE: bosch wae24363 washing machine, coming up with f17 error code please help
low water pressure
Posted on Mar 14, 2008
Bosch washing machine error code f17.any solution ?tks
The F17 error code is generated by the computer when there is a problem with the water supply.
Check to see if any of the valves are shut off or the filters on the hoses or where the hoses connect to the washer are blocked or restricted. Clean if needed and try it again.
If all that checks out, then you have a problem with the inlet valve on the washer, where the hoses are attached to the back of the machine.
Aug 22, 2016 | Bosch Washing Machines
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Oct 15, 2012 | Siemens Washing Machines
Anyone know what code F17 means on my HE5t washer and how to fix it
sorry no i/we dont know i have seen this question in mant various froms here this morning we all know F25 code but i and suspect everyone has no idea what the F17 means since i have seacrhed and can not find any reference to it anywhere on the various sites i use to look up Whirlpool Duet error codes...nor in my years in the fileld servicing Duets have i ever seen the F17 code
Sep 28, 2011 | Kenmore Elite HE5t Washer
F17 error, what does it mean?
My list for Siemens/Bosch states 'F17' as being 'inlet valve problem'. Sorry- service call ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 13, 2011 | Siemens Washing Machines
Machine is displaying F17 have cleaned out filter still having problem with dryer not working
Hi.
F17 means that there is poor or no water inlet detected.
From user manual: F17 Turn the tap on fully, check that the supply hose is not kinked/jammed; clean filter (see page 10 of manual). Also check water pressure is not too low.
If that does not fix the problem, then inlet valve, pressure from the house and water pressure switch must be tested. The defective part must be replaced.
Regards.
Ginko
Jun 18, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
What circuits are on fuse number 17 30amp
F17 is for the Transfer Case Shift Relay in the power distribution box. The junction box under the hood f17 is not used
Nov 28, 2010 | 1999 Ford Super Duty F 450
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
1,807 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
