USB to ATA/ATAPI Bridge
My Acer desktop is unable to install the USB to ATA/ATAPI Bridge driver, i am unable to connect my USB drive, please help.
Cheers
Balaji
  • 4 Answers
1)solve and proper connecteted usb in usb port
2)not detected additional usb cable in communication port(com1)connected
3)ceque virous affected this system.then re install in new OS.
Posted on Sep 25, 2008
I recently restored to factory settings on my HP laptop.once restored I then input my Iomega drive into the USB port to access some of my saved files.
Just to be on the safe side, why not plug in your iomega drive into another known working computer and see what happens. If it works fine and is properly recognized then the anomaly lies within the software of your laptop.
U might want to contact HP - but be fore warned that they are terrible for support if your unit is "out of warranty." If that is the case I would simply google the anomaly and in all likelihood you will get links that will help you fix it yourself.
Apr 06, 2015 | Iomega Usb 500Gb 3.5 Desktop Select...
Acer Extensa5620z originally had Vista, I wiped the hard drive and installed W7. Its not as simple as I thought. Now I need to update drivers and Acer.com doesn't have anything listed. In the det
Windows 7 should automatically install device drivers for the Audio, Video and Network, If you are unable to find/download a device driver that works on your computer and your computer is connected to the Internet then - 1. Remove the driver that isn't working if it was installed.
2. Set Win-7 "Windows Device Installation" to 'AUTO'
3. Windows will automatically search the internet for the driver.
4. Reboot your computer.
Mar 19, 2013 | AU Optronics Acer Extensa 5620-4801...
I keep getting a (logical unit crc error ultra dma 32) when trying to burn files onto a disc, it does'nt matter what disc i use or whether i use the internal or a third party external burner
These problems are caused by a 40-pin cable that i used in the past for previous hardware (old drives)
You need to put in the 80-pin cable for the burner that came with the device.
May 23, 2011 | Zoom USB-ATA/ATAPI Bridge Controller
Recently purchased eGo Helium 500 GB USB Drive. During installing on Win XP SP3 system it fails the USB to ATA/ATAPI Bridge portion of the installation and reports a problem in the balloon.
I have this external hard drive myself although mine is a 25gb drive. When you first tried to install it did you insert the disk that came with it first? You may need to do this if your system isn't recognising the drive. According to the system requirements it should be compatible with your system. Good luck. Andrew
Jan 18, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
I want to replace CD drive on Dell Dimension 8200. My options are serial ATA, parallel ATA & ATAPI. Which one do I need?
This computer has 2 IDE connectors. These are parallel ATA connectors.
See: Dell Dimension 8200 Specs
If you get a drive, look for IDE on the package. IDE, PATA and ATAPI are near synonomous. They use a 40 pin flat ribbon cable to connect.
Thanks for using Fixya.
Nov 25, 2009 | Dell Dimension 8200 PC Desktop
Plugged in an usb to ata/atapi bridge(ext HD)
There are a couple of possiblities but first you have to try the external hard drive into another computer, if this works then you may have a problem with USB drivers or the IRQ
if the external hard drive didnt work with other computer, then it is possible that the ext hard drive does not have working partition and or a logical drive,
to check this right click you computer icon then click Manage.
On the left side select Disk Management, then you should be able to see all your harddrives even the cd rom drive from there right click and create partion for any un partitioned drive.
Nov 02, 2009 | Computers & Internet
Dvd driver gone
do one thing ...
click on start > right click on my computer > properties > hardware > device manager > and go under cd/dvd and see if the drive is listed there and if it is there right click on it and uninstall it and than go under the option that says IDE ATA/ ATAPI and uninstall the secondary channel and than restart the system hopefully you will get the drive back if that doesnt work out than open the tower and disconnect and reconnect the data and the power cable attached to the non working drive and if that doesnt work the change the power connector which should be an extra one in the cabinet and than also change the data cable and if that too doesnt work than ur drive gone bad
change it
Feb 17, 2009 | Acer Aspire T690 (AST690UP820A) PC...
I NEED DRIVER UPDATES BUT I DONT HAVE A REG.KEY....
hiiii ther
how r u ??
go to acer.com u will findall the vista update to ur driver
but 1st u need to check if ur machine is compatible with vista if it is
u will find all the update on the acer.com under ur laptop model
if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 22, 2008 | Acer Aspire 3680 Laptop
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Sep 09, 2008 | Compaq Armada M700 Notebook
Computers & Internet Logo
4,279 people viewed this question
David Payne
David Payne
