Question about ASUS Motherboard Striker II Formula
Asus Striker II Formula
Hi im having problems with my new Asus Striker II Formula motherboard ive installed it all and when i boot up the LCD screen is came with shows a error code as M56 and wont boot up any devices can you please let me know what i can do as ive tested all connections and all seems fine even got a new power supply to see if that was the problem its been like this for a few days now and would love to get back on my computer thanks
  • 1 more comment
  • Adam Dower
    Adam Dower Sep 25, 2008
    hi nothing will load up not even the graphics card so my screen will not turn on
    its like a freeze on all devices any other info you could give me would be great thanks
  • Adam Dower
    i found this on the INTERNET
    “The review sample we used for this test was the third Striker II that Asus had sent in for testing, with the previous two boards exhibiting two different faults before dying. We were therefore pleased that our third retail-boxed Striker II managed to power up at all. However, after many failed attempts to get the board to POST with an overclocked FSB, our third review sample joined its predecessors in silicon heaven and refused to boot at all.”
  • Anonymous Nov 02, 2008
    i have asus striker 2 extreme and have this same message when booting it says error m56.all fans are working but screen stays black.any sugestions on what i can do would be great.
  • 320 Answers
Try to boot up with minimum configuration ie: graphic card , and memory, check BIOS configuration
Posted on Sep 25, 2008
I have an Asus Striker Extreme III motherboard running a q6600 with 4gb of patriot 1066 ram and an asus 8800 gtx video card. My computer has run fine for the last 3 years and had been working fine. Then a...
This sounds like the power supply - before buying a new motherboard can you get voltages from the pin connectors that power the board? You can use a simple multi-meter - set to 12V and register the current.
May 01, 2017 | ASUS Striker Extreme Motherboard
ErrorM56
A branded computer uses Original Equpment Manufacturer (OEM) version of Operating System, hence if you change any hardware it will go to the trial version of OS automatically. Hence, you have to use the full system recovery disk to reinstall the OS.
Thanks and regards,
Nov 13, 2010 | ASUS Motherboard Striker II Formula
My MB (maximus II formula) dosn't boot at all
Hi Sounds like the motherboard has fried
However i would recommend the following
1) Take out the 3 pin lead at the back of your PC/MB (the one that looks like a kettle lead)
2) Hold in the Power button on the Motherboard for 20 seconds........you will see a small burst of power
3) Retry...if this fails you will need to take it in for repair
Feb 10, 2010 | ASUS Maximus II Formula Motherboard
Where can I get a manual in ENGLISH ((~: Striker II formula T3472
From the manufacturer's web-site, you can download a "multiple languages" version:
http://www.asus.com/Product.aspx?P_ID=wOFZuyplXj0vLmAc
Select the "Download" tab.
Select "WinXP".
Expand the "Manual (16)" branch of the tree.
Select the specific model ("T3472").
Select the "Multiple Languages" version;.
Nov 05, 2009 | ASUS Motherboard Striker II Formula
Asus Striker II Formula CPU INIT
u motherboard stop of working is fault get another one from a it very professional
Sep 01, 2008 | ASUS Striker Extreme Motherboard
2 much memory?
First make sure your motherboard can handle the size memory stick you are attempting to install, find out the Max amount of RAM the board can handle per slot. If you are within the range then do a memory test after it is installed to see if the memory is good or has issues. Check out http://www.memtest86.com/ for a bootable memory test program.
Jul 10, 2008 | Computers & Internet
Asus maximus formula
Yea- its really simple with the Maximus Formula's (well.. I have a Maximus II Formula....)
Under the BIOS, you should have a tab called "extreme tweaker" or something similar. Go under that and there should be a nice CPU level up option. For example, mine has 3 options: (i have an E8400)
1.) Auto
2.) E8500
3.) Crazy
Another solution is to get the ASUS utility called CPU Level Up. It installs under windows, and lets you switch your CPU settings easily. Although this may be a Republic of Gamers specific utility.. not sure.
Jul 01, 2008 | ASUS Maximus Formula Motherboard - 45nm...
ASUS STRIKER FORMULA
This Is A Processor error Message, CPU ( Central-Processing-Unit ) INT ( Intermittent Fault ) wrong Type Installed. ( Faulty Processor ) Disconnected Fan-Wire To Motherboard ?
Or if It,s INIT Then It Fails To Initialise The CPU.
Is The Board Auto-detect Settings ? Or Jumpered ?
Mike @ Compurepair.
** Please don,t Rate This Post until Your Problem/Issue Has Been Resolved**
Feb 27, 2008 | ASUS Striker Extreme Motherboard
Asus m2n-e sli Cpu changed settings on boots up
I could not find BIOS ver. 1302 for the M2N-E Mb. What I do know: Your dual core 4200 showing up as "unknown". Asus says:
This is because the BIOS does not have the relative CPU uCode to support this processor. Please simply update your BIOS to version 0902 or later to resolve this problem.
BIOS 0902 can be downloaded from the link below:
http://dlsvr01.asus.com/pub/ASUS/mb/socketAM2/M2N-E%20SLI/0902.zip
Once you cpu shows up correctly, chances are that your over clocking will work and the bios will stop sending you back to change your settings.
Dec 11, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS Motherboard Striker II Formula  Logo
855 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
