Question about Sharp AR-M455N Copier
What is network error (CE 03)
When try to scan, the machine can't send the scanner to the email direction and send me the message "Network Error (CE-03)
    New Friend:
  • 80 Answers
There is something not setup at all on the webpage or setup wrong on the webpage of the copier to allow you to scan to email. Need an IT guy make sure that your SMTP, DNS and reply address are correct on the webpage of the machine.
Posted on Nov 08, 2011
Scanning document to email. 20 pgs. Get "Error Type: Transfer" result report. What does it mean? Running Firmware version 2GR_2000.022.001 2008.08.06
Error Type: Transfer means your scanner/printer is having an issue transferring the documents to the place you want it to go. This usually means the device can't find a network or you've typed in your email incorrectly.
Did you type your email in correctly? Are your networks settings correct and working?
Are you able to send just one page to test it out?
May 12, 2011 | Computers & Internet
I'm trying to use my Sharp AR-M355N as a scanner for the first time. I've already made sure it's properly hooked up to the network and have successfully printed to it. I scanned a test page, put in the...
When scanning to e-mail you would need to enter the details of a smtp server e.g. Gmail, as well as your DNS settings into the photocopier via the web browser. To access the browser, enter the I.P. address of the copier into the web address & this will give you the front page of the copier. To access the network settings you'll need the user name : admin & the password Sharp. Depending on the firmware version the machine must have SSL installed, if it hasn't then unfortunately you will not be able to scan to e-mail. The alternative is to scan to SMB (folder), again this is set up via the web browser.
Hope this helps.
Dave.
Aug 26, 2017 | Sharp AR-M355N Copier
I am an IT pro who has an AR-M355U. We are having a problem with some new email addresses we entered. We changed the suffix of the address to a new service, and the decive stopped sending scans to our...
CE-O3 = The specified server suspends reponse during transmission of images.
Cause: Improper connection of the network cable, An error occurs in the SMTP server/FTP server/ NTS
Check: Check that the network cable is properly connected.
Check the SMTP Server/FTP server for any trouble.
Aug 23, 2010 | Sharp AR-M277 Black and White Copier
Sharp AR-BC260 shows the network error CE-02
You need the Sharpdesk Software CD and you will have to install it in order for the scanning function to work.
Feb 03, 2010 | Sharp AR-BC260 Color Copier
Network error CE-02
You didn't tell me enough about the problem. Are you trying to scan from a PC or to a PC? The problem is that the network address changed when you moved the printer. You can fix this by correcting the network address
Nov 23, 2009 | Sharp AR-M162 All-In-One Laser Printer
Sharp arm 450n (ce-02)
1) If you're actually scanning to an email address, make sure your SMTP email server information in the copier's web page is correct.
If you are using names instead of IP addresses, also make sure your DNS server IP's are correct.
2) If you're scanning to create the fake email set up by Sharp Network Scanner tool, the connection info in your copier is old and needs to be refreshed.
From the computer you're trying to scan to, right click on the Network Scanner Tool icon in the tray, go to Automatic Profile Update, and select Update Now. If you have no tray icon, reboot your computer.
If your copier is set up to store names instead of IP addresses, make sure your DNS information is correct in the web page.
Jun 30, 2009 | Sharp Office Equipment & Supplies
Sharp MX-M350N Error CE-03--We changed ISP providers and can't get Inbound routing to an email working again. I changed smtp server in "Network Setup". The "Connection Test" passes for SMTP. We can email...
CE-03 is a communication error, obviously. Your print card and your new SMTP are not talking together. Your system is probably OK at this point, but is unable to communicate well with the new network system. Work with an IT department to resolve this.
Jun 02, 2009 | Sharp AR-M450N Copier
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Network Error on display
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
Sharp AR-M455N Copier Logo
3,012 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
