Question about RCA TH1500 MP3 Player
Freezing up.... It's Rechargeable via USB and charges fine....the radio works fine on it...but when i proceed to add mp3 files it locks up...it's only been used a handful of times and has been unused for some time...
  • 8,596 Answers
Make sure the mp3 files that you are adding are definitely in Mp3 format, rather than AAC, CDA or WMA. If they are mp3, then check the sampling rate - try cutting the sampling rate in half through Windows Media Player. Also, if you obtained the songs through Limewire, delete all songs from the device, clear out the "Comments" line using the "Advanced Tag Editor" function in Windows Media Player, and then reload them.
-Tha Mp3 Doctor
Posted on Sep 26, 2008
Wont turn on when not plugged in. but will turn on if charg plug is plugged in and you turn on the power switch and unplug the charger it will stay on but wont play, keeps coming up format error.
Customer Reviews: Kubik Evo 8GB MP3 Player with Radio ...
www.amazon.com/Kubik-Player.../B0041MMMWW
Amazon.com, Inc.Find helpful customer reviews and review ratings for Kubik Evo 8GB MP3 Player with ... Con's - Wonder if some of these items can be fixed with a firmware update. ... Just push the main button (or any button) and it will turn on and function as usual. ... 2) Play while plugged in charging works with the wall charger, but still NOT ...
Evo won't charge via USB ' Android Forums
androidforums.com > Android Phones > HTC EVO 4G
Jun 29, 2010 - Whenever I plug in my Evo, I select Charge Only (or if I do nothing, it selects Charge. ... If I turn off my Evo it charges from the USB fine. ... Check your computer's stats... what does it say about its USB status when your Evo is plugged in or ... I had a problem a while back where it would charge via USB, but not ...
Dec 29, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
Tip
Cannot Add Any More Files to Mp3 Player- New Breakthrough
I have a stunning new breakthrough on the frequently cited problem - "I cannot add any more songs to my Mp3 Player." Before we proceed, I am assuming that the reason you cannot add any more files has nothing to do with available memory space. Of course, if your Mp3 player is full, it will not accept any more songs. But, I am assuming that this is not your problem.
Apparently, if you add too many folders, especially via Playlist, via Windows Media Player, the Mp3 player's file system will become unstable - it can only handle a certain number of additional folders.
To resolve the issue:
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Now, when music is transferred, it will be placed in the root directory of the flash memory disregarding the folder structure and allowing all tracks to be seen.
This procedure was designed for Siren Mp3 players, but is applicable to many other Mp3 players. It is not a guaranteed fix for every Mp3 player and every error of this type, but it is certainly not a widely known or reported solution. i hope that this benefits many Mp3 player owners who are experiencing this issue.
-Tha Mp3 Doctor
on Jun 14, 2008 | Philips GOGEAR SA6045 MP3 Player
My jlab (same set) does the same thing...any fix for it?
It works only via USB to PC because that is not only the way to transfer MP3 files from your PC to the player/headphones, but one way to charge the player's battery. You can also charge the player with the USB cable by plugging it in a USB wall charger. So let it fully charge in the PC or the wall charger and then take it with you while you walk, work out, etc. There is nothing wrong with your player (maybe the fact that there is no indicator when it is charging and when it is fully charged ??).
Dec 28, 2014 | JLab Audio GO Waterproof MP3 Headphones...
My rino 655t wont take a charge
That unit has a special charger and harness.
Very similar to the Motorola
The Rino 650 and 655t includes a rechargeable lithium-ion battery. If the battery is not charging, ensure the battery is secure and the device is connected via the included A/C charger. The battery will not charge when connected via USB cable.
May 02, 2014 | Garmin Rino 655T Topo Gps 2-Way Radio
My nextar will not turn on and it is straight out of the packaging. When the usb is plugged in, the two default songs are listed, and they are able to be played. Please help me with this issue, as I...
I think you have a new device and you wanted to use it at first and the battery wasn't charged.
The player has a built-in lithium-icon rechargeable battery. It is charged via USB connection. You
are required to charge it when you use it for the first time. It takes about 3 hours to fully charge the
battery. Connect the larger end of the USB cable to the USB interface of PC, and connect the
other smaller end of the USB cable to the USB interface of this player. The device is connected to
PC and being charged.
For maximum performance, lithium-ion batteries need to be used often. If you don't use
the device often, be sure to recharge the battery at least once per month.
I hope your item will work fine after the battery is charged.
Thanks.
gylacz
May 03, 2011 | Nextar MA797 MP3 Player
Want to watch movies
Looks like it only plays .mtv files, so a converter may be needed before uploading video files to the 610.
Try these links for converters, info, etc.:
http://www.imageconverterplus.com/help-center/about-icp/supported-formats/mtv/
http://www.openwith.org/file-extensions/mtv
http://www.sharpened.net/extensions/file/mtv
Product Description: Coby MP6104GBLK MP6104G 4GB Color Display Flash MP3 Player Radio.
1.8 inch color LCD display.
Integrated flash memory.
Plays music, video, photos, and text.
Integrated FM radio.
ID3 and LRC support for song and lyric information display.
USB 2.0 Hi-Speed for fast file transfers.
Integrated rechargeable battery.
Color: Black.
Memory Capacity: 4GB.
Display Type: 1.8 inch TFT LCD.
Display Resolution: 128 x 160.
Media Support: Integrated Flash.
Format Support: Audio: MP3, WMA; Video: MTV; Photo: JPG; Text: TXT.
OS Support: Windows Vista/XP/2000.
Menu Language Support: English, Spanish, French, Portuguese, Italian, German.
Additional Functions: FM Tuner.
Audio Output: 3.5mm Headphone.
PC Interface: USB 2.0 Hi-Speed.
Power: Integrated Rechargeable Lithium Polymer Battery.
Battery Life: Capacity: 350mAh; Audio Play Time: 8hr.
Unit Dimension (WHD): 1.65 x 3.66 x 0.38 inch.
Helpful?
Mar 23, 2011 | Coby MP-610 MP3 Player
Hae bought 2gb Veg MP4 players. Can add music files to players when connectd to computer. But have tried to charge on numerous computers and they won't charge. Anybdy got any ideas or know how to fix? ...
Try to charge it via a battery charger. Change a USB cable to connect PC to make sure the USB cable is good. And change PC to charge the mp4 player. Compare the results, you will know where the problem is.
Jan 09, 2010 | Umax Vega108 MP3 Player
Probleme s50 usb conect pc
You have to use My Sirius Studio as the interface to your S50 to add/remove MP3 songs. Depending on your Windows version (hopefully 2000 or later) you should be able to connect via USB and Windows will autodetect the device. My Sirius Studio is a poor man's iTunes where you have to add music files before you can drag them to the playlists you created on your S50. You can download the software from the Sirius web site, including the latest update. Keep in mind you have to disconnect the S50 from My Sirius Studio. You can't copy files to it and then unplug the USB cable.
Dec 02, 2006 | Sirius Satellite Radio S50-TK1 Satellite...
Charging using USB
Did it worked before? if so It can be something with the USB cable, try diff cable. USB port, try diff port. Also, you can reload the driver, sometimes it helps. It can also be that the internal fuse has possibly blown, unless you are good with a soldering iron it's not a user servicable part as such. If it never worked: Try the driver first. (the original) Good luck.
Dec 26, 2005 | SanDisk Sansa e140 MP3 Player
RCA TH1500 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
